Wiring help needed
Old Oct 29, 2012 | 10:32 AM
BEJ's Avatar
BEJ
Default Wiring help needed
Can someone tell me what this wire goes to? When I took the interior apart, I labeled it "heater control" but I can't find anywhere that it could possibly attach to. If you can't tell, it is running in the same group of wires that the cigarette lighter power is in. Any help would be greatly appreciated.
Thanks,
Bryan
Old Oct 29, 2012 | 10:37 AM
tomgallucci57's Avatar
tomgallucci57
not sure,but could be the light for the ash tray
Old Oct 29, 2012 | 10:59 AM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
That looks like the ground wire for the heater light/cig lighter. Should be male tab mounted to the metal bezel that the female plug slides onto.
Old Oct 29, 2012 | 11:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Could be console plate ground wire. The should be a spade terminal on the underside of the trim plate.
Old Oct 29, 2012 | 11:38 AM
BEJ's Avatar
BEJ
I agree that it has to be a ground wire, but unfortunately, the only terminal on the underside of the trim plate is on the cigarette lighter. Assuming that it is a ground, couldn't I just extend the wire and ground it somewhere else?
Old Oct 29, 2012 | 12:02 PM
Raphiki's Avatar
Raphiki
The cig lighter spade is not a ground. That should be a red (I think) heavier wire. You can actually ground anywhere on the bezel. Might want to be sure it's actually a ground wire before you go too far.
Old Oct 29, 2012 | 12:11 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by BEJ
...the only terminal on the underside of the trim plate is on the cigarette lighter...
What model year?
I agree with Raphiki: lighters have only one connection and that's the hot. They ground through the console trim plate.
How about right here? Call out #5:
Old Oct 29, 2012 | 12:57 PM
BEJ's Avatar
BEJ
It's a 75. I agree that the terminal on the cigarette lighter is not a ground. The orange wire in the picture with the female connector is the power for the cig lighter. The question remains then, what is the black wire? It looks like it should be a ground but where does it connect to?
Old Oct 29, 2012 | 01:13 PM
Easy Mike's Avatar
Easy Mike
...It's a 75...It looks like it should be a ground but where does it connect to?...
Try UPC 12 Sheet B2 in the AIM and see if you don't have the same spade terminal on the underside of the console. The 68-76 consoles and plates are essentially the same. The terminal for the ground is on my 68 and was on my 74.
Old Oct 29, 2012 | 01:42 PM
BEJ's Avatar
BEJ
I found it on UPC 12L Sheet 14 in the AIM. The terminal has gone missing from my console but I will just make an alternate connection. Thanks to all for the assist.
Bryan
Old Oct 29, 2012 | 01:43 PM
lvmyvt76's Avatar
lvmyvt76
the ground for the cigarette lighter is a large ring that goes around the lighter base. You have to unscrew the base to take it off.
Old Oct 29, 2012 | 04:02 PM
Easy Mike's Avatar
Easy Mike
I found it on UPC 12L Sheet 14 in the AIM. The terminal has gone missing from my console but I will just make an alternate connection. Thanks to all for the assist...
To Wiring help needed
