Transmission numbers
Old Nov 3, 2012 | 05:40 AM
cue487023's Avatar
cue487023
Default Transmission numbers
Hi all you Corvette Gurus,
I have just removed the motor and transmission from my 79 C3 for a freshen up. I have not had the car long and I was told the transmission is a TH350. I am a long way from being a mechanic so I wouldn't know a TH350 from any other transmission. I have found some numbers on it so can someone tell me what the numbers mean. The markings are GM34, H168, & 6260233.
Thanks, Colin
Old Nov 3, 2012 | 09:45 AM
oldalaskaman's Avatar
oldalaskaman
http://www.google.com/imgres?hl=en&s...r:16,s:0,i:120
Old Nov 3, 2012 | 10:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If your tranny is original, you will also find your VIN derivitive stamped on it.
Old Nov 4, 2012 | 04:50 AM
cue487023's Avatar
cue487023
Cheers. I am pretty sure it is a TH350. Thanks for your help.
Originally Posted by oldalaskaman
Old Mar 21, 2019 | 04:52 PM
GoGo87U's Avatar
GoGo87U
xxx
To Transmission numbers
