I recall the frame rail side has a bracket it screws on to. But what about the engine side ? I'm prepping the engine to be removed.
Not sure if mine was ever installed correctly or if it s the same as yours, but I just took mine out recently for a trans overhaul, clutch, etc. Once I had it unbolted from the frame side, I lifted it a bit to clear the bracket that it mounts to and pulled it off the ball stud on the block. (after disconnecting all the other linkages of course)
be careful when you remove that nut on the frame side of the "Z" Bar
there is a special washer that holds the shaft from turning in that notch
don't loose that special shape washer it will ruin your week
BTDT............s
