Alternator Bracket
Old Nov 20, 2012 | 12:30 AM
Skip Burney's Avatar
Skip Burney
Default Alternator Bracket
Does anyone make a nicer alternator bracket than the old universal one with the big curved piece. I want something nice and clean looking with the adjustable rod ends for belt adjustment.
Old Nov 20, 2012 | 01:45 PM
MelWff's Avatar
MelWff
Try this link
http://www.summitracing.com/search/d...ew=productname
Old Nov 20, 2012 | 02:00 PM
toddalin's Avatar
toddalin
Do you run headers? Header Power Brackets makes an assortment of beautiful pieces to work on either side of the engine.
My Header Power Bracket.
http://headerbracket.com/
Old Nov 20, 2012 | 05:20 PM
Ironcross's Avatar
Ironcross
Nice clean and simple part that really works
Old Nov 20, 2012 | 08:12 PM
Skip Burney
I like that bracket but what does it use for a belt tensioner? I really want to get rid of that big curved tensioner and go with something nicer.
Old Nov 20, 2012 | 10:43 PM
toddalin's Avatar
toddalin
You still use the F-bracket so you do need a tensioner. You can use a rod with spherical ends, like you see on the aluminum aftermarket bracket, but would need a small piece of aluminum to clear the alternator. (Hmmm, new product idea for use with my new machine!)
Or you can use two of the curved tensioners and make it look unique while really firming things up. Just takes a few chrome bolts and three 1/2" wide aluminum spacers spun in the drill against some compound for a nice polish.
Old Nov 21, 2012 | 02:12 PM
dugcyn's Avatar
dugcyn
Custom made mine. [IMG][/IMG]
like the ideas above too
Old Nov 21, 2012 | 02:37 PM
tyancey00's Avatar
tyancey00
THAT IS OUTSTANDING!!!
i like the double, yes, but this is really nice work.
Old Nov 21, 2012 | 04:46 PM
briankeery's Avatar
briankeery
Check out Alan Grove Components.
Old Nov 21, 2012 | 08:01 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
How about this one: http://www.summitracing.com/parts/sm...model/corvette
Old Nov 21, 2012 | 08:26 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
I think you're looking for something like this:
Can still use the bottom bracket also. Made these up last summer when my upper bracket broke.
Old Nov 21, 2012 | 09:18 PM
TPI BOY's Avatar
TPI BOY
Nice
Old Nov 21, 2012 | 10:03 PM
Tim H's Avatar
Tim H
OMG thats cool, Im using 1 right now and am going to investigate the set up you have, again that is really cool!!!!
Old Nov 22, 2012 | 01:49 PM
toddalin's Avatar
toddalin
That's what I'm talkin' about. I may just need to start making something like that too.
Old Nov 22, 2012 | 03:40 PM
TPI BOY's Avatar
TPI BOY
Originally Posted by Raphiki
does this one really work, will the pulleys line up
because of the vetts spacing
Old Nov 22, 2012 | 05:01 PM
Raphiki's Avatar
Raphiki
After looking again it seems this bracket only fits through '68.
Old Nov 23, 2012 | 01:23 PM
Skip Burney
I like that too and I can make that one out of some 6061 bar stock
To Alternator Bracket
Old Nov 23, 2012 | 04:11 PM
sfrank2886's Avatar
sfrank2886
You can buy those brackets at Jegs. Tension bar is not cheap, but looks good on mine! The lower bracket may not fit your heads, but I just painted mine up a gloss black and it is good to go.
Old Feb 23, 2013 | 04:33 PM
msteno's Avatar
msteno
Has anyone tried this one? I know it says Vette, but you never know. I have a SB 68'
Old Feb 23, 2013 | 04:35 PM
msteno's Avatar
msteno
Has anyone tried this, preferably for a small block?
