headlight door question
Old Nov 26, 2012 | 11:31 PM
Skip Burney's Avatar
Skip Burney
Default headlight door question
Why does the left headlight door open and then close everytime I start my 73 after it has been sitting for a while
Old Nov 27, 2012 | 01:25 AM
Legacy Stables's Avatar
Legacy Stables
because it likes to wink at you every time you start her up.
my best guess would be that the head light is leaking air some where and the vacuum from your engine corrects the issue some how. I know that if you pull the head light switch under neath that it opens up the line and that will pop the head lights up so it would seem that there is a leak that gets corrected or over powered buy the constant vacuum of a running engine.
get a diagram start pulling hoses one by one and vacuum check them. also put your finger over the actuator vacuum tubes and make sure that it wont move with either hole plugged. good luck
Old Nov 27, 2012 | 04:25 AM
dgood's Avatar
dgood
These 2 links should help you out.
http://willcoxcorvette.com/instructi...function_2.pdf
http://willcoxcorvette.com/instructi...ted_080509.pdf
Old Dec 14, 2012 | 11:03 AM
MikeV1's Avatar
MikeV1
6th Gear
Thanks for the diagram and repair worksheet....Have a Merry Christmas, Mike V
Old Dec 14, 2012 | 03:11 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the in line filter,first.
To headlight door question
