Lt1 ???
Old Nov 28, 2012 | 10:05 PM
johnnyw's Avatar
johnnyw
Default Lt1 ???
I have a 1971 convertible and I noticed that it has what I understand is a LT1 tachometer. Are there other things to look for that are less noticeable I can check out? I'm not sure if one of the hoods I have is the car original hood and I know the motor is not the original but what else might be looked for to tell if it was ever a LT1? Here's the tach picture, can you see the 6500 red line.
Old Nov 28, 2012 | 10:39 PM
Hammerhead Fred's Avatar
Hammerhead Fred
That would help explain your copper radiator and lack of an expansion tank.
Base engine 350 w/4sp had an alum radiator w/expansion tank.
LT-1 came with copper (automatic style) radiator an no external expansion tank on the fender.
Old Nov 28, 2012 | 10:55 PM
johnnyw's Avatar
johnnyw
I'm not even sure if the radiator is original, it is fun trying to decipher this cars history though.
Thank you for the info!
Old Nov 29, 2012 | 09:56 AM
roadblock69's Avatar
roadblock69
What is the rear axle ratio? Most LT-1 cars were geared at 3.70 : 1. Tank sticker would be another indicator.
Old Nov 29, 2012 | 10:30 AM
jaxlt1's Avatar
jaxlt1
What data is on your shifter console plate?
Old Nov 29, 2012 | 10:31 AM
Brooklinite's Avatar
Brooklinite
Transistor ignition?
Old Nov 29, 2012 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
An LT-1 without the LT-1 is not an LT-1.
Do the Google thing. There's been enough written about LT-1s to put together exactly what the options package required. Once you know that, you can start looking for the tell-tale parts.
Old Nov 29, 2012 | 01:13 PM
Crafty12's Avatar
Crafty12
Here is a post from when I was buying mine. There is a good list on the second page.
http://forums.corvetteforum.com/c3-g...ting-tips.html
To Lt1 ???
