I was tightening the mechanical fuel pump cover on my 82. It's not the stock engine but its just a 350 and I have an electric fuel pump now. Anyway, the bolt head got broken off flush with the block. I tried some bits to get it out but it just won't come out. The only thing I can think of is pulling the engine, drilling it out, and tapping it. But I don't have a lift and my shops asking $1200. Any suggestions on how to get this bolt out?
Once you have given it your best with using drill bits and then easy outs, I would try to see if possibly someone could weld a stud or bolt onto the broken bolt and then you might be able to get it to come out. You might also try heating the bolt before drilling it. The best will be getting a hole drilled down into it and then going with and easy out. Use the largest drill bit you can.
Good luck.
Don't know if you have enough room for this, but I worked in maintenance in an automotive parts plant for 34 years. Try cutting down a small chisel and after soaking the broken stub, try spinning the bolt out at it's rim with the ground down chisel. You have to go in a circle with the bolt hole threads. Lou.
If it's stuck because it is cross threaded, drill the bolt carefully for the next size smaller (yes smaller, it's just a blocking plate) bolt, tap the hole and Bob's your uncle. A flat washer will aid clamping force. Grease the drill bit and tap well and clean both a lot so you don't fill the oil pan with swarf.
If you need more clearance than removing the tire and dust shielding will allow, removing the motor mount bolt on that side will allow you to gently force the engine either up or down a bit to gain better access. HTH.
Not sure what the diameter of the bolt is, but if it's large enough you should be able to tap the bolt a using a smaller diameter. Then screw a bolt into it that has the new diameter, once it's tightened it should start to turn the broken bolt. Just make sure you tap it with the threads going the direction you need
Find a nut that's a few sizes larger than the snapped off bolt. The nut should fit over the exposed stud loosely. Take your wirefeed welder and weld the nut to the stud making sure not to weld outside the nut. You basically want to start in the middle and weld in a spiral from the center to the edge. Wait about 10-15 seconds or so and remove it with a socket wrench. The heat from the welding will break the rust bond between the bolt to the block.
This trick works like a champ. I've used it a bunch of times. It's quick too. The whole process will just take a couple minutes. If the stud is broken clean to the block, then you may want to carefully weld the stud and build it up. Maybe cut the nut in half so it's not as tall so you can weld down to the stud. Good luck!
I've tried the left handed bits and the easy outs. I feel like welding it would cost just as much since I don't have a welder. And the lift for a Christmas present sounds good to me!
