Installing a Kenwood KDC-252U receiver
I am in the process of replacing my factory radio and with a Kenwood 252U. The question I have is on the wiring:
1. Is there an aftermarket pigtail harness I can use to connect the receiver to the connector coming from the vehicle (used to be connected to the original radio)?
2. If not, I have no idea where to attach the "dial light" line coming from the car (the power and ground lines are self explanatory, I think). Any ideas?
Thanks as always.
Earlier cars, no adapter.
Can't help you with the adapter harness, I rewired my radio with a new harness fro
A seperate fuse box and used the original 12V and ground for the mandatory fog light. The grey wire however (light) I connected to the head unit so the radio dims when you turn the headlight switch.
Nick
