Daytime running lights
Old Dec 4, 2012 | 07:06 PM
The Punisher's Avatar
The Punisher
Default Daytime running lights
Has anyone wired in daytime running lights like the c5 has? Interested in how and what materials used. Thanks
Old Dec 5, 2012 | 09:57 PM
Mooser's Avatar
Mooser
I've been playing around with the Audi style (well, everything has them now) DRL in various configurations
I think Paul74 had his DRL in the marker/turn signals. (maybe not, his would be amber too)
Were you thinking on replacing the front turn signals or ???
Mooser
Old Dec 5, 2012 | 10:23 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
I built a set of LED halo headlights earlier this year, and put them through a long term test over the summer. They look awesome! Each headlight has 96 LEDs, they are extremely bright, even during the day. I use them as my DRLs with the headlights down. They turned out so well that I am currently almost finished building a set of LED halo tail lights
Old Dec 6, 2012 | 04:32 AM
riverracer au's Avatar
riverracer au
when i was looking at drl's, i found this little DRL-1 unit, but they wont ship to me..
http://www.webelectricproducts.com/products.htm
Old Dec 6, 2012 | 09:34 AM
Fast81's Avatar
Fast81
One of the big parts places sold a conversion kit for C3 DRL's but i cant remember which one..........(Zip, Ecklers, MidAmerica, or CCentral)
Old Dec 6, 2012 | 10:41 AM
Paul L's Avatar
Paul L
I had that system on my 1974 for three years. It worked very well but unfortunately the control module failed last summer. Strangely they no longer will ship to Canada as well?? It only takes five minutes to fill out the customs form....
For spring I will probably do something along the lines of Mooser's work.
Old Dec 6, 2012 | 10:50 AM
MAXCO's Avatar
MAXCO
That looks really cool.
How did you make them?
Old Dec 6, 2012 | 04:04 PM
redman76's Avatar
redman76
St. Jude Donor '09
I installed regular 55W fog/driving lights
Old Dec 6, 2012 | 07:10 PM
7t2vette's Avatar
7t2vette
I am not ready to share all just yet. When I am done building and testing the halo tail lights, I will start a thread.
Old Dec 6, 2012 | 07:56 PM
Fast81's Avatar
Fast81
Found them. Ecklers and CCentral sell them = pricey @ $180-200
Old Dec 6, 2012 | 09:01 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Why not just do this...
http://www.ecklerscorvette.com/corve...1953-1982.html
...tho I'd still dedicate a switch to enable them.
Old Dec 6, 2012 | 10:27 PM
The Punisher
That looks like it would work. Are there any brighter bulbs available ? Or are the stock ones sufficient
Old Dec 7, 2012 | 12:29 AM
TheSkunkWorks
IIRC, the 1157 bulb's turn signal element is typically a bit brighter than its running light element. You could have someone hold the brake pedal down with the flashers on to see if that's bright enough. (You might be surprised.)
Thing is, they'd probably burn out before too long with continuous use, and I'm not sure whether or not having them on for long periods might create heat issues either within the lamp, socket or wiring.
Fortunately, there are probably some very bright LED replacements of suitable quality for the 1157 out there, but I don't happen to know which to recommend at the moment. ...or what flasher modules you'd need with them.
Old Dec 7, 2012 | 06:22 AM
riverracer au
that looks like the same unit that i was looking at
will put it back on the to do list
and they have a sale on this weekend as well..... mmmm
Old Dec 10, 2012 | 11:39 PM
Ray Y's Avatar
Ray Y
Kind of like redman76's setup above, I used a set of 55w PIAA 1400 Dichroic Fog lights mounted behind the grills adjacent to the park/turn lamps. I like this set up because it's bright & the tail lights are not on so when you hit the brakes during daylight its more obvious to the person behind you.
Old Dec 11, 2012 | 02:12 PM
MAXCO's Avatar
MAXCO
No Problem....Cheers.
Old Dec 15, 2012 | 10:34 AM
The Punisher
Mooser
Is that a strip light ?
To Daytime running lights
Old Dec 15, 2012 | 05:23 PM
Mooser's Avatar
Mooser
Set of those high-intensity LED, water-resistant strips. 12v and originally meant for under-cabinet work.
They draw minimal amps and oddly enough the spacing works almost perfectly for the grill.
Tried a few different configurations
They make a set of smaller LED's that aren't quite as bright, these seem pretty good without using reflectors
Now that I've decided on a shape I'll make up some brackets and mount them over the winter. Right now they are just taped to the head-light guards (The strips have 3M foam tape on them)
Mooser
Old Dec 15, 2012 | 07:44 PM
Paul L's Avatar
Paul L
Do you have a link to those?
Old Dec 15, 2012 | 08:55 PM
The Punisher
Mooser
Those are nice and bright
