Paint or wait?
Old Dec 11, 2012 | 07:38 AM
jamsleybond's Avatar
jamsleybond
Navigator
Default Paint or wait?
I have a 74 and about half of the paint on the car is not there anymore. I can see the fiberglass fibers, but they are smooth and not sticking up. Would it be wise to go ahead and get a paint job or wait until after I have done some restoration to the motor? I am thinking of doing the paint first so that it protects the fiberglass and doesn't leave it exposed for the elements. BUT if it really is not that big of a deal leaving it as exposed as it is, then I can wait and don't have to worry about the paint job while I work on the motor. Or maybe get a cheap paint job just to protect it and then get a good one after I am done with the engine bay work?
Old Dec 11, 2012 | 08:27 AM
Leo23's Avatar
Leo23
I would get the mechanical stuff taken care of first, so you don't have the worry of messing up your paint while doing the engine over. Don't get a "cheap" paint job just to cover it, as it will only add extra cost later, as it will likely need to be sanded off before you get a "real" paint job.
Old Dec 11, 2012 | 08:30 AM
AdamMeh's Avatar
AdamMeh
If you have bare fiberglass showing, you will need to be VERY careful of getting grease and oil on it while working on the engine compartment. If it soaks in, it will come back to haunt you later.
Old Dec 11, 2012 | 08:36 AM
AirborneSilva's Avatar
AirborneSilva
I'd at least get a coat of epoxy primer on it...
Old Dec 11, 2012 | 09:35 AM
MikeKey's Avatar
MikeKey
I concur, epoxy primer. Do your work, then get it painted second to last. I'm personally in favor of interior after paint.
Old Dec 11, 2012 | 09:52 AM
jamsleybond
Navigator
I did a little research and like the epoxy primer idea. I read that Dawn dish soap is good to wash the surfaces for dirt and such. I also do not have air guns or a compressor and was thinking the aerosol cans of epoxy primer looked like a good idea. I was either thinking of starting with the hood for practice and then doing the other exposed areas, but I also think it might just be a good idea to just primer the whole car. Thoughts?
I also am still looking up what to do before spraying the primer. I know to clean the surfaces of grease, dust, etc.... Dawn dish soap, but I also read to use a rough grit sand paper on the painted areas to help it grip. I assume the surfaces don't need to be that even since you sand the primer smooth before paint. I will continue to see if they have "how to" posts in the forum as well.
Thanks for the help!
Old Dec 11, 2012 | 10:03 AM
jamsleybond
Navigator
I apologize for the lack of knowledge on the subject. This is all a first for me. I have only really dealt with mechanical problems and never tackled any type of painting. If you know any threads that can help me or websites, that would be great.
Old Dec 11, 2012 | 10:07 AM
AirborneSilva
Go to the paint and body section of this forum
Old Dec 11, 2012 | 11:32 AM
jamsleybond
Navigator
OK, plan of attach:
Get an orbital sander with a rougher grit.
Lightly rough up the exposed fiberglass to help with bonding the epoxy to it
Rough up the existing portions that have paint on them
Smooth out all the transition spots where the painted portions meet the exposed fiberglass
Wash and rinse using Dawn dish soap and let dry
Finally us an aerosol epoxy primer and do the whole outside of the car
I will make sure to update on this thread when done!
Old Dec 11, 2012 | 11:36 AM
AirborneSilva
Wash the car first with dawn otherwise you will just push the grease/oil into the fiberglass...
Old Dec 11, 2012 | 11:39 AM
jamsleybond
Navigator
Originally Posted by jamsleybond
OK, plan of attach:
Thank you! Added
Old Dec 11, 2012 | 11:41 AM
AirborneSilva
Good deal, and I only know that from reading the forums
Old Dec 11, 2012 | 01:11 PM
rogman16's Avatar
rogman16
OK, plan of attach:
Thank you! Added
I would move it up to #1...
Rogman
To Paint or wait?
