Changing fuel pump on a 82?
Old Dec 14, 2012 | 12:17 PM
alconk's Avatar
alconk
Default Changing fuel pump on a 82?
My fuel pump is getting weak in my 82 so I'm going to replace it with a 86' unit, but my question is is it best to change it with little gas in the tank or full? I'm just concerned about fumes in my heated garage.
Old Dec 14, 2012 | 02:50 PM
MelWff's Avatar
MelWff
Always little gas to make it easier to work with. If you worried put the container containing the gas and the tank outside and bring everything back in as needed.
Old Dec 14, 2012 | 04:47 PM
alconk's Avatar
alconk
Well i'm not removing the tank it's staying in the car. I'm just a little worried about having the gas lid opened with the guts removed in my garage with the furnace going. Fumes??
Old Dec 14, 2012 | 04:59 PM
jdp6000's Avatar
jdp6000
Fumes can ignite. Be carful. They are heavier then air.
Old Dec 14, 2012 | 05:33 PM
alconk's Avatar
alconk
exactly my point but do I fill up the tank or run it low? The lower the tank the more fumes I would think...
Old Dec 14, 2012 | 08:22 PM
TimAT's Avatar
TimAT
Warm the shop up, shut the furnace off, and get busy.
Full will have less airspace for vapors to build up in the tank, but if it's warm the vapors will still come out of the tank and fall to the lowest level.
To Changing fuel pump on a 82?
