Trying to verify the original color for my black '79 Vette. Accordng to information I have the correct code should be 19. Paint code found on the door is 67L. I cannot find any reference to 67L. Can someone point me in the right direction find the original color for this car?
GM had a standardized trim code system across all cars lines on two-tone paint schemes. U= upper section of the car, L= lower section. Single colour cars showed just the L on the trim tag.
The people in charge of inventing myths and legends frequently state that the U = urethane paint and L= lacquer.
Hello Zeker,
I have a friend that has that color. When I first saw it, I also did not like it. But that color grows on you every time you see. I am really starting to like it.
Nelson 007
Hello Zeker,
Nelson 007
Thanks for the encouragement. I sure hope you're right. The car is very clean with original engine and transmission and from what i've checked so far correct serial numbers and date codes on other equipment. I gotta go with the original paint color.
Zeke
