Question for you painters
Old Dec 24, 2012 | 12:02 AM
L84s R Us's Avatar
L84s R Us
Default Question for you painters
I have a question for you painters out there. I painted a lot of cars twenty years ago, but now I am going to go the base coat, clear coat route.
My question is, after I have sprayed the sealer, then I have put down the base coats, and I end up with something in the paint. I am talking about something bigger than a razor blade edge would fix.
What I am getting at is sanding at this stage. Can I sand? If so, wet or dry? What grit paper? Bigger than that, when should I do it and what needs to be done before clear coat.
Do I need to lay another layer of base down? It is a solid color (red).
I guess if you could talk me through that whole process of having some dust in the base coat, how would I fix it.
I figure it better to ask now than when I am standing there with the clear mixed and I see some dirt in the paint.
Thanks,
Old Dec 24, 2012 | 12:18 AM
GS977's Avatar
GS977
not a problem, just let the base dry then wetsand with 800. i use 3m p800 or sometimes p600. i wouldn't go courser than 600. the finer the better. than spray some color over the sanded area and after it dries your ready for clear.
Old Dec 24, 2012 | 01:10 AM
GPGG70's Avatar
GPGG70
Really? It's that easy? I'm going to be painting some items like a hood and going to do the BC, CC and L84 asked the question first. So thats all I have to do.
Thanks for the info. I appreciate it.
Old Dec 24, 2012 | 05:55 PM
stinger12's Avatar
stinger12
It all depends on the system you use. Is it water based or solvent based?
Old Dec 24, 2012 | 09:20 PM
GS977's Avatar
GS977
yes i forgot to ask......my advise is for solvent base.
if you can sand the imperfections out with 1000 grit that would be best.
Old Dec 24, 2012 | 09:35 PM
stinger12's Avatar
stinger12
My advice is for water based. That is all we use in Canada now due to VOC regulations, and the stuff is great. My boss has sprayed hundreds upon hundreds of vehicles with the solvent based paints back in the day, and now he sprays with the water based paints. He said he wished they had the water based paints back when he was pumping tons of vehicles through a shop.
To each his own...you can get great results with either. If you get dust in waterbase you do not wetsand it. you dry sand the spot with 600 and the rest of the procedure is just like solvent based products.
Old Dec 25, 2012 | 03:43 AM
540 vette's Avatar
540 vette
How easy is it to spray water base at home. I don't see how it will work in a garage setting.
Old Dec 25, 2012 | 03:46 AM
540 vette's Avatar
540 vette
Be carful going to fine when sanding. The paint may not stich if the paper is to fine. I had that problem on my 99 hood. On a solid color I have used 400 to rough it up before you recoat it. On metallics and others go with the finer. I have been painting for 40 years.
Old Dec 25, 2012 | 05:00 PM
stinger12's Avatar
stinger12
Come to think of it you are right. The stuff only dries with air movement! So you are correct, spraying it in a garage would be a disaster. It is some amazing stuff though, the clear coat is still solvent based like the rest of the solvent based systems.
To Question for you painters
