I have a 78' vette that I am currently working on an auto to manual swap. I have installed the clutch petal, but I need to know where on the frame to weld the clutch crossover shaft frame bracket. The engine and transmission are not in the car so I need a reference point on the frame. The diagram that the kit came with does not provide that location.
Sorry Joshua, this is the last decent image I'd taken for this position. As mentioned from a previous post, disregard the double spring from the cross-shaft lever to the steering mount; I found the correct spring later.
Hope it offers some help and good luck.
Reason: add text
