Engine install FAQs
Old Jan 10, 2013 | 10:05 PM
goatjacket's Avatar
goatjacket
Default Engine install FAQs
Sorry for the NooB questions but searching doesn't get to the point.
I have my 68 ready to go for the 427. After many years in storage (15+) the engine has been reassembled and ready for me. I last saw the car and motor together before I entered the service years and years ago. Sorry...to the point:
I was planning on having the motor installed by a Shop or referenced friends. A few friends however insist it will be fun to do it ourselves. Mind you I've NEVER attempted an engine pull or install. With the 4speed still in the car after all these years, how feasible is it for a motor novice to get the block in on our own? Ill still need to assemble the tri-power and other accessories later, but what about just the block assembly? Any major pitfalls or steps to be weary of? I'm decent at taking apart and reassembling...but I've never seen the "together" part before
Thanks for any tips or experiences.
Old Jan 11, 2013 | 06:23 AM
scottw's Avatar
scottw
I did it by myself with zero experience. Between "How to Rebuild your Chevy Small Block" the AIM and this forum, I was able to pull my old motor and replace it with a crate engine very easily. Just make sure anything you want to do to the motor bay is done before you put the engine back in.
To answer your question, I would save the money, rent a cherry picker, and install the engine yourself. If you run into any problems, this forum is full of very knowledgable people that help out.
Old Jan 11, 2013 | 06:36 AM
donnie1956's Avatar
donnie1956
Search for videos on youtube. We pulled my buddies engine out and reinstalled 3 times last year. Last time we had it pulled in just under 2 hours. Remove the hood and get some good fender protectors. Take pictures along the way.
Old Jan 11, 2013 | 08:14 AM
540 vette's Avatar
540 vette
Just be careful doing this job.An engine weights 400 to 600 pounds. Don't take that for granted.
Old Jan 11, 2013 | 08:16 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
If you took it out, you can put it back in. Use your head; it's not rocket science.
Good luck and hold off on the congratulatory beer until after it's in.
Old Jan 11, 2013 | 08:50 AM
oldalaskaman's Avatar
oldalaskaman
support the trans in its aprox. location with a floor jack, put the car up on jack stands so you can get under if needed, dont install the exhaust manifolds or distributer till the engine is in, do everything....slowly. crank up the rock n roll, break out the beer, assign one person to be designated beer go getter...I sometimes leave the motor mounts off till the engine and trans are mated.
Old Jan 11, 2013 | 08:35 PM
blue427's Avatar
blue427
Two things weren't mentioned,if you come in from the frt you'll need a long cherry picker c-3 have a long frt endor you could come in from the side of the car. Get a load leveler(rent don't buy a cheapy)they are a big help in tilting the engine.
Old Jan 11, 2013 | 09:25 PM
fishslayer143's Avatar
fishslayer143
you said 4 speed? be sure to align the clutch disc before you start to put the motor in and always install a new throw-out bearing and Pilot bushing
Old Jan 12, 2013 | 10:44 AM
goatjacket's Avatar
goatjacket
Thanks for all the tips and advice! My confidence is building after these posts. My trouble is lack of experience, the motor was pulled for the rebuild before I owned the car. In fact I haven't seen the motor complete in so long! The advice of aligning the clutch disc is huge! These are things I don't know of. I'm looking for a step by step procedure on this as I'm a previous instruction kind of guy. I've heard from the side is best due to the long nose. The manifolds, distributor and radiatior are all off or removed. I've grown accustomed to what that empty engine bay looks like. Keep these tips coming ll, I really appreciate it!
To Engine install FAQs
