gear ratio
Old Jan 12, 2013 | 09:59 AM
mikes c3's Avatar
mikes c3
Default gear ratio
Hi all. Antone know where I can find a Formula to figure out what rear gears I'm running? Thanks in advance.
Old Jan 12, 2013 | 10:58 AM
avner's Avatar
avner
Hi, the simple way to calculate is to put the rear wheels in the air turn the rear wheel one turn and count how many turns make the main driveshaft.
you will get your ratio.
Avner
Old Jan 12, 2013 | 02:36 PM
mikes c3's Avatar
mikes c3
Thanks. Doesn't wheel size play a part in that?
Old Jan 12, 2013 | 03:24 PM
BKbroiler's Avatar
BKbroiler
No. Turn the wheel one complete revolution and count the driveshaft revolutions. The driveshaft revolution count is your ratio i.e. 3.08:1, 3.36:1, 3.55:1 etc.
Old Jan 12, 2013 | 03:37 PM
BKarol's Avatar
BKarol
FYI in 78 there were two std rear axles for automatics:
L48= 3.08 or high altitude 3.55
L82= 3.55
Probably one of these unless someone went in.
Old Jan 13, 2013 | 01:02 PM
mikes c3's Avatar
mikes c3
Thanks. I have not put her up in the air yet. Just seems like 2700 at 60mph is high.
To gear ratio
