Fuel Rail Fitment Issue
I kinda like this fuel rail and filter and am determined to somehow make it work. I had a couple of thoughts:
1. Bend the fuel inlet lines that screw into the carb downwards. By doing this, it possibly might help clear the coolant hole and also possibly move the pressure gauge away from the air cleaner base. (I currently cannot get the base to sit flat because of this) The only problem I see though is that there is only maybe 1/2" clearance between the intake and the bottom of the fuel rail. So bending the lines may not work out. I really don't want to bend them only to find out this idea will not work...
2. Somehow extend the length of the inlet lines that go into the carb about an inch or so, which would move the fuel rail closer to the valve cover and also move the pressure gauge down and away from the air cleaner.
If I were to somehow extend the lines an inch or so, are there any kind of adaptors I can use? I believe the fuel line fitting threads are 5/8" - 18. I looked at local parts stores and hardware store, but could not find any type of adaptors like this. Maybe there is another type of fitting I can buy that would extend the fuel rail? maybe I should consider another type of fuel rail?
Any suggestions would be helpful. Thanks!
here is a pic, not a close up but you can tell
Then run your fuel line to the back.
BUT I really think the short 90° fitting is a better idea.....
