Dashboard Replacement question on 81
1) How many bulbs are there?
2) What type of bulbs are they?
3) Should I replace them with the same ones or are there other options
that I might like?
4) I’m planning on replacing the clear lens covers for the speedometer,
tachometer and gauge's.
Anything else I should replace while I have it all open?
Thanks.
that I might like?
Thanks.
2. Check hot water control vacuum switch.
3. Check all HVAC acuators for proper operations.
4. Seal all HVAC duct connections with appropriate material.
5. Check wiper switch for operation.
6. Check headlight switch and all vacuum hoses.
7. Check circuit board for instruments.
8. Check speakers and wiring connections.
9. Check all fuses and replace if in doubt to condition.
10. Replace all bulbs so you never have to go back in there again.
11. Test everything you have done before re-assembly.
scorpion18z has given you some excellent things to check. I'd change the wiper switch and headlight switch while your in there. There is a reproduction wiper switch that just came out. I didn't want to do this job again. Willcox Corvette's website has instructions on how to access the switch and clean it, if you decide to reuse your old one.
There are roughly 20 or so bulbs. The owner's manual calls for 194 bulbs although you can use the 168 as it is slightly brighter. Others have replaced the bulbs with plugin led bulbs. Many posts on what type to purchase. I didn't like the blue look of the led bulbs on the gauge faces. I think I purchased the wrong type of led bulb. I am very happy with the way mine turned out. You can actually see the gauges at night now.
The bulb in the dash above the ac control is a special bulb available at Willcox Corvette.
Good luck!
Do you have the 81 assembly instruction manual (AIM)? It can help getting things apart and putting everything back in.
The 81 kit contains 49 bulbs, and does the dash, courtesy, and all of the exterior lights except the headlamps. Also included are instructions telling you where every bulb goes. It's a lot easier than going to the parts store, and trying to identify 30 or 40 different bulbs.
If you still want to go to the local parts store and pick out your own bulbs, the 81 owners manual lists the part numbers for all of the bulbs in the back of it. Though you may have a hard time finding the special projector bulb locally, that goes in the center gauge bezel, to light the console. The bulb is still available, but I think they only come from Delco.
and the same LED spec bulb will work with either the 168 or 194 designations......
