Wiper door assembly
Old Jan 18, 2013 | 09:24 AM
edgreutman's Avatar
edgreutman
2nd Gear
Default Wiper door assembly
I recently bought a '68 corvette that needs some work. When I got it the wiper door assembly was totally taken apart and in pieces mixed in with other random parts. I bought a new vacuum actuator and vacuum hoses but I don't know exactly what I'm missing or exactly how to put it back together.
Does anyone have an exploded view or video or something that could help?
Ed
Old Jan 18, 2013 | 10:04 AM
rafalc's Avatar
rafalc
Ed
May the force be with you....
I decided to adjust the wiper door on mine to even out the gap between the door and the hood, well.... taking it off was easy but putting it back together...oh boy... I must have lost 2 of those plastic washers as they dropped in that mystery hole behind the fenders, only then I closed those holes off by stuffing rags in them.
I would recommend the AIM or maybe someone can scan the pages for you when it comes to the vacuum. Also, I think Willcox has some diagrams.
Good luck
Old Jan 18, 2013 | 10:09 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Does anyone have an exploded view...that could help?...
The 68 assembly instruction manual (AIM) shows all of it, shows how it installs, and lists the orignal GM part numbers.
Order the AIM and the GM chassis service manual. Both will help with your 68.
Old Jan 19, 2013 | 12:00 AM
68/70Vette's Avatar
68/70Vette
I recently bought a '68 corvette that needs some work. When I got it the wiper door assembly was totally taken apart and in pieces mixed .....
Ed
Look at the bolt holes in the wiper door. Did the attaching bolts shear off and leave part of the bolt inside? This is a common occurrence when people remove the wiper doors. I have a couple of suggestions if you have this problem.
To Wiper door assembly
