Stumbles on takeoff
From experience, most of them are 'taching it up' before they launch hard, so the engine already has some RPM's going. Same with a four speed car. You're gonna be giving it a good deal of gas before you even dump the clutch so it doesn't die or stall out on you at the light, I mean line.
If you don't have a high RPM stall converter in your trans, you may not be having any trouble at all. If you do... then that's a different story. And anybody else, please feel free to add, because I'm just surmising here.
anyway, take short piece of fuel line that will fit snuggly over the vertical vent "stacks" on the bowls, jump from one stack to the other making a nice smooth arch in the hose, then take a sharp knife and cut a small round hole in the top of the hose right in the apex of the arch. this will keep the fuel from sloshing out of the front bowl vent into the throttle blades which basically causes the motor to flood out just for a few seconds then it picks up and runs good.
anyway, take short piece of fuel line that will hit snuggly over the vertical vent "stacks" on the bowls, jump from one stack to the other making a nice smooth arch in the hose, then take a sharp knife and cut a small round hole in the top of the hose right in the apex of the arch. this will keep the fuel from sloshing out of the front bowl vent into the throttle blades which basically causes the motor to flood out just for a few seconds then it picks up and runs good.
Sure can't hurt trying that and that was on my mind too, I just didn't know what caused it. I'd still advocate a stall converter too, if he's going to be racing it regularly.
The problem is that when the secondaries kick in, the A/F goes dead rich and this creates the bog you feel. Eventually it recovers. This dyno sheet will show exactly what I mean. Note the drop in power accompanied by a 10:1 A/F. Eventually, this fuel atomizes and is used and the A/F returns along with the power.
A partial cure was to use the smallest squirters offered by Holley (21 vs 25 stock). This actually took care of most of the problem, but as shown in the following, not entirely. CarCraft Magazine also had this problem with their 600 dp and epoxied the squirters and redrilled them to 22 then realized Holley offers 21s. They said it fixed their bog too. Note that the A/F ratio in this plot is approximately 1.2 lean based on my prior readings and a bunch of other guys with late modeles with on-board A/F meters who also had their cars dynoed at the time/event.
The next step was to change the Holley pink pump cam on the secondaries from the more "mild" setting of "2" to the more "wild" setting of "1" that is supposed to provide a bigger pump shot. But don't believe anything you read about the "1" vs "2" settings because on a 600 dp secondaries at least, I found that all the literature is bass-ackwards based on my testing, and the "2" shot is much larger than the "1" shot.
This seems to have alleviated the bog, but I've not dynoed the car since.
corvette brothers you guys are terrific like my combat veterans helping each other out.
My brother totally disconnected the rear pumper on my Holley, because my engine and the horsepower it has, doesn't even need that much fuel! It was running way rich and you could smell the gas all the time (does this sound familiar Bob, if not, then ignore this) and after he was done, the car ran much better and didn't smell nearly as rich! It still revved hard all the way to the redline.
All he did was remove the adjuster on the back pumper.
I'm not saying for sure this is your issue, but as I said, it's cheap, fast and reversible
He told me that my engine doesn't need the double pumper feature. Try this out. With the air cleaner off, engine off and the carb exposed, pump the throttle linkage just a little bit, not even 1/4 of the way and watch the secondaries. I instantly saw fuel squirting into the secondaries and they weren't even barely open yet!
The carb was squirting fuel into the secondaries all the time! The linkage is on the rear of the carb and the squirter can be found under the float. It's a squat little metal square and you'll see a linkage with an adjustment. If you have this situation, then go ahead and remove the linkage and you won't have that extra, unnecessary fuel squirting into the secondaries.
Right away, the richness went away, the gas smell inside the car went away and it sure ran a lot cleaner and got better mileage after that. A double pumper is only necessary for a high horsepower engine that demands that amount of fuel.
http://www.badasscars.com/index.cfm/...d=79/prd79.htm
"First of all, lets take a 600 double pumper, like Holley's #4776. It's a great little carb but as the throttle is pulled back, the primaries begin to open and a shot of fuel gets squirted down the throat from the primary accelerator pump. When the primaries get about halfway open, the secondaries begin to open (mechanically) along with another shot of fuel through the squirters, from the second accelerator pump, hence the name "double pumper". This is all fine and dandy unless you've got an automatic transmission, a heavy car or high rear-end gears and you stab the throttle off the line. The engine will probably choke, cough and spit before it sluggishly starts to go"
Another article:
http://www.mustangandfords.com/techa...s/viewall.html
3. Vacuum Secondaries vs. The Double-Pumper
Assuming you've got spot-on tuning, a carb with vacuum secondaries is easier to live with on a street car or one that sees only limited duty on the dragstrip. That's because the secondaries kick in automatically for more consistent performance; and they usually deliver better fuel economy. Vacuum secondaries are also tailored for the typical street-engine combination, such as a dual-plane intake and a "smaller" camshaft, as well as an automatic transmission-all of which typically provide better vacuum signals.
A Double Pumper carb with mechanical secondaries is controlled strictly by your right foot and uses an accelerator pump to shove more fuel down its throats when you quickly go to WOT. It uses more gas this way, but is more accommodating to big cams, single-plane intakes, and other vacuum- limiting factors. These qualities generally make the Double Pumper better suited to high-rpm combinations used mostly at the track.
Actually, the above Mustang article has some great tips on bogs and hesitation too!
My combination:
331 CI, pump-friendly 9.5:1 CR
K&N 14"x4" air filter, Corvette drop base and lid
Holley 600 dp, choke horn milled and blended, Primary - 69, Secondary – 74, Squirters - 21
1/2" Aluminum open spacer port matched to manifold, exterior polished
Edelbrock Performer RPM intake manifold, port matched, exterior polished with all extraneous castings and lettering removed
Homemade lifter valley splash shield to keep hot oil off manifold bottom
Manifold heat riser crossover blocked
Camel hump 1.94/1.50 heads hogged out to 2.02/1.60, pocket ported, port matched, pump-friendly hardened seats, 3-angle valve job
Cylinder bores clearanced to unshroud the valves
Comp Cams 1.52:1 roller-tip rockers
Crane Cam Vintage Muscle 327/350 hp cam, 222 degrees @ 0.05, 0.447" lift (with 1.50 rockers)
Doug Thorley headers, dechromed and ceramic-coated
2.5" mandral-bent exhaust (including tips), 2" cross-over just before rear axle
DynoMax stainless Ultra Flow mufflers
Millerspeed 1-1/2” Gilmer under drive belt drive system
Mallory Hyfire IV CD ignition box triggered off Accel points
Mallory high voltage chrome coil
Mallory spiral-wound coil wire
Mallory solid copper plug wires, ends soldered to wires
Champion plugs
37 degrees total ignition advance
Carter high volume fuel pump
Melling high volume oil pump
Open breathers
Polished aluminum high flow water pump
160-degree thermostat
Flex fan with polished aluminum spacer
Polished aluminum one-wire 100 amp alternator
Header Power Bracket
Keisler TKO600 5-Speed
Hurst shifter
3.70:1 positraction with Big Block yokes
225/60/15 Firestone Firehawk SZ50s on 7”-wide Western 30-spoke Turbine Wheels
Does even better in colder temps as shown in these older runs. There's that bog again.
Slightly modified 600 dp.
