Door Panel Removal
Old Jan 20, 2013 | 04:21 PM
gireland's Avatar
gireland
3rd Gear
Default Door Panel Removal
I am starting a project to replace the driver side mirror. To do this I have to remove the window crank and door handle. I have looked over several books, youtube and discussion boards and I can't find the clip that hold these on. I tried the window tool with no luck.HELP!!!!!: I also tried to remove the clip with a thin rag. I just need to see a picture and the best way to remove the window crank and door handle.
Anyone have pictures or video?????
Old Jan 20, 2013 | 04:32 PM
yyz1970's Avatar
yyz1970
Behind The crank handle has a C clip that can be removed with a paper clip ( shape the paper clip like a fish hook) and pull
the door handle is a 5/16 bolt I think I used a 1/4 drive socket set with a long extension
If you have trouble with the window crank Youtube it
Good luck
Old Jan 20, 2013 | 04:37 PM
gcusmano74's Avatar
gcusmano74
Yes. Bent a short hook onto one end of your paper clip and pull the C ring off that way.
Old Jan 20, 2013 | 05:13 PM
goldengoat2's Avatar
goldengoat2
I take an old fork, cut all but 1 of the prongs and bend the end thats left with needle nose plyers
Old Jan 20, 2013 | 11:32 PM
68/70Vette's Avatar
68/70Vette
You do not have a 68, 69, or 70 Corvette. Helps to state the year.
Old Jan 21, 2013 | 10:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I am starting a project to replace the driver side mirror...
Before you get too far into your project, order the assembly instruction manual (AIM) for your model year. It will show you the clip you're looking for, how the mirror installs, and how to put the door panel back on.
To Door Panel Removal
