1979 corvette troubles
Old Jan 25, 2013 | 10:15 AM
Meangreen_217's Avatar
Meangreen_217
Default 1979 corvette troubles
I bought a '79 corvette, with a new motor, and the only problem the car has is that the belts squeal really bad. Enough wear caused my alternator belt to break so I put new belts on it and it still wearing them out the same. I was wondering has anyone had to adjust the powersteering and alternator, and how much work is it? By looks of it the power steering is pushed to far out and this is causing my troubles but I don't know what power steering will fit. Thanks.
Old Jan 25, 2013 | 10:33 AM
MrJlr's Avatar
MrJlr
Post some nice clear pictures and we'll probably figure it out for ya...
Old Jan 25, 2013 | 11:50 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Sounds like the replacement engine wasn't a Corvette engine, and it has incorrect pulleys on it, causing a misalignment.
Old Jan 25, 2013 | 01:36 PM
Meangreen_217
i will get pics soon, but i dont think you will be able to see just from a picture because of how minor the changes are to get it right but once i figure out how to post the pics i will. and the replacement engine is a corvette engine, the guy bought it from boss hoss.
Old Jan 25, 2013 | 03:57 PM
tyancey00's Avatar
tyancey00
Boss Hoss does motorcycles dont they? If you look real close are there any washers behind the mounts to push them out farther? that is all you would have to do is take out the washers...
Old Jan 25, 2013 | 05:59 PM
leadfoot4's Avatar
leadfoot4
Originally Posted by tyancey00
Boss Hoss does motorcycles don't they? If you look real close are there any washers behind the mounts to push them out farther? that is all you would have to do is take out the washers...
And I'm sure that Boss Hoss does whatever they need to do, in order to get the "Corvette engine" to fit in their motorcycle frame...
Old Jan 26, 2013 | 11:46 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Purchase the 79 assembly instruction manual (AIM). The AIM shows all of the factory pullies and brackets, shows the correct installation, lists part numbers for them, shows the correct belt routing, and lists part numbers for the belts.
To 1979 corvette troubles
