New Least Favorite Job = Vacuum Tank Removal
Received 3,139 Likes
Only minutes to remove the tank. 6 small bolts easily accessible from the wheel well. 3 hosed slipped easily off 3 pipes
A little over an hour to remove the steering column (OK, I wanted it out for another reason) to get at the P/B bolts easier (I've been down this road before) and that hideous clip/pin on the brake rod/pedal
Then you can move the PB boaster/master out of the way to allow for the tank to come pivot out. (OK I took the booster/MC off but again, that's another story)
Just to add to the hilarity, drivers seat is still in, cannot open the door all the way, car is off the ground about 18"
One the plus side, the steering box was already out so I didn't have to remove the one bolt on the coupler.
Add this to the list of easy jobs that are a pain because of everything else that's in the way
Radio Removal (those two nuts on the cluster, even using the 1/4 extensions/swivels up from the side)
Gas Line (body on)
E-Brake console (that one nut at the back, sure you can go in from the jack storage bay but really?)
Headlight Switch Replacement (I may put a new one on now while the column is out just because)
C3 Engineers, I want to shake their hands while I kick them in the hoohaa's
I choose to do this
Mooser
Gas Line (body on)
I choose to do this
Mooser
The following 2 users liked this post by Mooser:
ballen06 (10-19-2020),
Rescue Rogers (03-24-2019)
Mooser
You are hilarious. Just listening to your frustration over all the same nasty encounters with our beloved C3s makes me want to laugh...at least now. I sure don't laugh every time I find another one...which I am sure there are many more lying in wait.
FR
FR
And they were huge, with additional brackets just in case you thought it would sneak out
I've read that on a manual brake car you might be able to loose the MC enough to pivot it aside and sneak the tank out. Not going to happen with P/B.
Next time I'll do it the easy way and remove the front clip
Mooser
1969/1971/1976 Coupes
ckirsch100 (10-18-2020)
"...and if we make the belt short enough on the power steering, then they can see the cap and even touch it, and it'll be possible, but it'll be easier to check the fluid level if you actually take the alternator off."
Mooser
The following 3 users liked this post by Mooser:
I seem to remember taking my vacuum can out through the fender grill opening.
I still envision Duntov and the boys sitting around the office during morning meetings going;
Mooser
Mooser
So they went to the trouble of putting that plate there just to make us think it'll fit?
My 68 convert has the vacuum operated headlight and wiper door mechanisms removed, but I left the vacuum tank in place. One look convinced me it was a three hour job, so I just left it in place even though it now does nothing except take up space in the left fender well.
