427 Intake manifold question
yes they are square port too
3947801 Aluminum 390 Horsepower 427 engines
3937795 Aluminum 400 Horsepower 427 engines
3937797 Aluminum 435 Horsepower 427 engines
39333198 Aluminum L88 and ZL1 427 engines
http://www.superchevy.com/technical/...y/viewall.html
polished up, you cannot tell the difference as the numbers would be gone
There are actually 2 L-88 manifolds, the 67 (3886093), and the 68-69 (3933198). The 3933198 was also used on the 69 ZL-1.
The 427/425 intake is found with 3 different casting numbers. 3885069 for 66-68 427/425's, 3919878 for 68 427/425's and 3933163 and for 68-69 COPO 427/425's. All three of these intakes, were also used on 396/375 engines, and the 163 was also used on the 68-69 aluminum head 396/375's. Obviously, not all of these applications are Corvette.
Besides the modified plenum, there were probably some other minor differences, but the basic intakes are the same. All of them are designed for use with a standard bore Holley, and include provision for an intake mounted choke.
Even though both intakes are rectangular port, I don't think they can be used with the newer "Bow Tie" big block heads.
It would definitely take a high rise compatible hood.
