C-3 Power Door Lock Problems
Old Jan 29, 2013 | 12:04 PM
Psychovette's Avatar
Psychovette
Default C-3 Power Door Lock Problems
The power door locks on my '79 only lock the right (passenger side) door, not the driver's side. Neither side will unlock when a switch is operated. I know that the switch connector plug on the driver side door needs to be replaced but I don't know if there are many other common problems to look for besides replacing the entire power door lock harness and both actuators. Anyone out there had experience working on these?
Old Jan 29, 2013 | 03:29 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Psychovette
I know that the switch connector plug on the driver side door needs to be replaced...
Start there. I don't see why harnesses or actuators need to be replaced if the connector will do the trick.
Old Jan 29, 2013 | 07:54 PM
spedaleden's Avatar
spedaleden
If that doesn't fix it, then move on.
Let us know!
Old Jan 29, 2013 | 08:06 PM
havesometo's Avatar
havesometo
When i got my 1980 neither switch would work. So i took the switches out and sanded the little pins on the back of them. They both work good now.
Old Apr 9, 2019 | 12:42 PM
rio9760's Avatar
rio9760
Default C3 door locks
when you mention switches are you refering to the actual door lock cylinders,?
Old Apr 9, 2019 | 03:31 PM
DB Cooper's Avatar
DB Cooper
Sounds like he's referring to the contact pins between the switches and their plugs.
To C-3 Power Door Lock Problems
