You'll need to carefully pinch the gray slide switch in the center and pull downward to remove it to access the bulb. Before messing with the fragile housing, you may want to check to make sure the wire is plugged into the fuse box.
Awesome. Those pics will help. Does anyone know what bulb goes into it?
Thanks!
Ben
