steering
Old Feb 1, 2013 | 04:02 PM
rays699's Avatar
rays699
Default steering
did some one add a power steering gear box to a 69 vette?
Old Feb 1, 2013 | 04:06 PM
tyancey00's Avatar
tyancey00
Borgenson, makes a box for our cars. to replace the stock system...
Old Feb 1, 2013 | 04:23 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
there is no such thing as a stock power steering box. the same one was used for standard and power. only the pitmen arm needs changed when going to PS
Old Feb 2, 2013 | 10:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you asking? C3s did not having power steering "gearboxes." C3s use a power assisted steering.
Old Feb 2, 2013 | 11:29 AM
rays699's Avatar
rays699
Default steering
i am installing a power steering gar box from borgeson on my 69 vette. it said to collapsed the column 1-2" for the new box + rag joint,did anyone do this on a 69 vette +how do you do it easy.
Old Feb 2, 2013 | 06:45 PM
Raphiki's Avatar
Raphiki
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18
I had to do it when I installed my R&P. Put a piece of wood on the end of the steering column shaft and hit it with a big hammer. Doesn't get any easier than that.
Old Feb 3, 2013 | 08:21 AM
Jim Shea's Avatar
Jim Shea
It is much better if you can apply a steady pressure to move the steering shaft back up into the steering column. Hammering on the end of the steering shaft can damage the bearings that support the steering shaft. Obviously, it's a lot quicker to just give it a whack.
There is a lot of overlap where the solid upper steering shaft engages the tubular lower shaft. The two shafts are originally held in place by injected plastic. You shear small plastic sprues when you move one shaft relative to the other. However, there are no safety implications in moving the lower shaft an inch or two.
Jim
Old Feb 3, 2013 | 10:19 AM
rays699's Avatar
rays699
how would you apply steady pressure on the shaft.
To steering
