76 side mirror replacement
Old Feb 6, 2013 | 07:53 PM
jdenn47's Avatar
jdenn47
Default 76 side mirror replacement
Driver's side mirror has a broken mounting screw at the surface of the door. Can't remove the screw stud without stripping the ID thread - easy-out doesn't work. not enough stud sticking up to grab with a vice grip. Removed the interior door panel but can't get to the inside threads. The other mounting screw thread is OK but how can I attached the other if can't get to the anchor thread inside door?
Old Feb 6, 2013 | 10:55 PM
sweeet76's Avatar
sweeet76
You might want to think about drilling that screw out and then drill a larger hole and install a well nut.This is the way a passenger mirror is installed, with the well nuts. Before you do this, please remember I said THINK ABOUT. I would not want to lead you down the wrong path.
