76 Corvette Front Spindle Bolt
Old Feb 10, 2013 | 06:50 PM
ed_in_pa's Avatar
ed_in_pa
Cruising
Default 76 Corvette Front Spindle Bolt
Anyone know what size the front brake spindle bolt is for a 76 Corvette? I don't have any sockets that big and need to purchase one.
Old Feb 10, 2013 | 09:40 PM
my 76 ray's Avatar
my 76 ray
The old school way is to use channel lock pliers on them. Snug it up while spinning the wheel until it requires a little effort to spin the wheel. Then back the nut off to the first place where you can insert the cotter pin. At this point the wheel should spin freely.
Old Feb 10, 2013 | 11:18 PM
Learning_Curve's Avatar
Learning_Curve
Any socket the right size willl most likely be for a 1/2 ratchet, and you will be tempted to over torque. It only needs to be tightened to JUST PAST what you can do with your fingers.
Old Feb 11, 2013 | 05:18 AM
palmbeachvette76's Avatar
palmbeachvette76
As my instructor in Automotive Service Technologies school told me "use the universal metric adjustable wrench"
my 76 ray is 100% correct
Old Feb 11, 2013 | 06:21 AM
scrappy76's Avatar
scrappy76
Old Feb 11, 2013 | 07:26 AM
71scgc's Avatar
71scgc
1-1/4" on my '71.
CSM spec's 12 ft-lb torque. then loosen to a point where the cotter pin can be inserted.
Just replaced front wheel bearings. Looked this up recently.
Carter
Old Feb 11, 2013 | 08:17 AM
ed_in_pa's Avatar
ed_in_pa
Cruising
Thanks all for your replies.
To 76 Corvette Front Spindle Bolt
