Motive Bleeder Question
My new Motive bleeder took well over 100 pumps and I couldn't get above 7 psi. I even tried plugging the connector, same thing. It held the pressure fine.
I ended up bleeding the brakes with 7 psi and didn't have any leaks. I'm thinking the pump is defective. Thoughts?
I can't believe I ever bled brakes any other way, even with all the hand pumping and at 7 psi.
Thanks.
