73 hood flapper switch
Old Feb 11, 2013 | 09:49 PM
73silververt's Avatar
73silververt
Default 73 hood flapper switch
Been replacing alot of things on the way to puttin car back togeather, just cause i'm there, piece is old or broke, or easier to do now than later, so when rebuilding gas pedal assembly was gonna repace the switch that activates hood flapper, nobody sells these anymore, and i've tried alot of vendors. Mine looks ok, slides easily back and forth. Anyway of testing?
Old Feb 11, 2013 | 10:20 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
Should be pretty simple. If the switch closes when depressed, it's good to go. Just test it for continuity.
Old Feb 12, 2013 | 12:21 AM
CA-Legal-Vette
Also, I forgot to mention that the switch is the same as the Kickdown switch for the auto transmission. Look it up with that description and see if it looks the same.
Edit:
Found the switches at Lectric Limited
http://www.lectriclimited.com/mainpage.htm
Scroll down to switches. There is one for 4 speed cars too. I assumed that they used the same switch.
Live and learn.
Old Feb 13, 2013 | 10:23 PM
73silververt
thanks for the help, i'll go that route
Old Feb 13, 2013 | 11:23 PM
Tom73's Avatar
Tom73
The switch is one in the same. Does double duty for both functions.
To 73 hood flapper switch
