air cleaner base
Old Feb 15, 2013 | 06:10 AM
69small block's Avatar
69small block
Default air cleaner base
Just put a q/jet on 69 350 it has electric choke on it origanal drop base air cleaner wont fit does anyone have base for a an elecltric choke that will clear my hood or any suggestions for air cleaner
thanks
Old Feb 16, 2013 | 12:47 AM
WHITE 1974's Avatar
WHITE 1974
I have an edelbrock drop base on my 74,I know I have a bit taller hood than a 69 but I also have a slightly taller than stock intake,sorry I cant provide a part number as the previous owner bought it,if you check an edelbrock catalogue there maybe something you could use there
Old Feb 16, 2013 | 09:13 AM
69small block
thnks for input
Old Feb 16, 2013 | 09:17 AM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Are you starting with the original Q-jet air cleaner base, or an aftermarket drop base?
Old Feb 16, 2013 | 03:31 PM
69small block
It is origanal for divorced choke
Old Feb 16, 2013 | 04:29 PM
thegazman's Avatar
thegazman
Default thegazman
I bought a dropped base last year off of e-bay for my q-jet with electric choke. If you look at "14" air cleaner dropped bases" on e-bay, the base needs to be rounded like the Proform to fit the q-jet with electric choke.
Old Feb 16, 2013 | 06:40 PM
c69vete's Avatar
c69vete
St. Jude Donor '07
I have dimpled the aftermarket style drop base air cleamer with a 2 X 4 backer and a ball peen hammer to clear the choke housing.
You might accomplish the same, even if it means a little work on the filter element as well.
Old Feb 16, 2013 | 06:51 PM
69small block
been looking at some online think I might have an Idea Like you said probably need a little reworking
Old Feb 20, 2013 | 09:04 AM
Sunstroked's Avatar
Sunstroked
If you have the hood clearance a 1/2" air cleaner spacer may do it.
To air cleaner base
