oils
Old Feb 16, 2013 | 05:37 PM
zac's Avatar
zac
Navigator
Default oils
hi guys, please somebody can help me?
i have to rifill the engine oil how many litres?
the automatic fluid how many litres and which type?
thedifferential how many litres and which type ?
than you very much and my corvette is a c3 1980?
Old Feb 17, 2013 | 10:19 AM
WHITE 1974's Avatar
WHITE 1974
OK These are from the Mitchell time manual,4.7 litres of engine oil originally 10w-30,this may start a major war but here goes I use full synthetic 5w-30 in my 1974. Your th/350 tranny uses Dexron 111.Fluid 2.8 litres if just draing and filling,or 11 litres if you are dropping the pan and torque converter. Rear diff. takes 1.8 litres of GL5/80-90 OIL Hope this helps you should post your location there maybe others near you who may be able to help in person.Cheers Eric
Old Feb 17, 2013 | 10:29 AM
wheatpj's Avatar
wheatpj
Old Feb 17, 2013 | 10:41 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by WHITE 1974
...tranny uses Dexron 111...
That's Dexron III (three) not one one one. Trying to save a little confusion when shopping for it.
The owner's manual lists all these.
Old Feb 17, 2013 | 04:48 PM
zac's Avatar
zac
Navigator
thank you very very much eric
Old Feb 17, 2013 | 06:59 PM
my 76 ray's Avatar
my 76 ray
That's 4.7 litres of engine oil if you also change the oil filter. If you don't change the filter then it takes almost 1 litre less.
Old Feb 17, 2013 | 11:34 PM
WHITE 1974's Avatar
WHITE 1974
When changing oil always change the filter,they are cheap.Changing the oil and not changing the filter is like taking a shower and leaving your underwear on....clean?but not really.
Old Feb 17, 2013 | 11:35 PM
WHITE 1974's Avatar
WHITE 1974
Where are you located zac?
Old Feb 18, 2013 | 10:55 AM
gcusmano74's Avatar
gcusmano74
Old Feb 18, 2013 | 11:57 AM
zac's Avatar
zac
Navigator
I'm in Italy, in the north Milan and thank you very much for your advise
To oils
