L46 and lower octane
Old Feb 16, 2013 | 07:52 PM
binster's Avatar
binster
Default L46 and lower octane
I have a 69 with the L46. A friend suggested I use an octane booster to avoid probs.
Opinions out there? I am sure I will hear both sides
Do these higher compression engines need something more than the premium I can get at the pump?
Old Feb 16, 2013 | 08:00 PM
gccch's Avatar
gccch
Mine ran great on 93 pump gas. It was bone stock. I added octane boost a few times and did not notice a huge difference.
Old Feb 16, 2013 | 08:24 PM
mikem350's Avatar
mikem350
The answer is...it depends!!!
On temperature, timing and advance curve, etc etc...list goes on
If you don't hear knocking pinging..you are prob OK
Stick w premium fuel
Old Feb 16, 2013 | 10:06 PM
Dave J's Avatar
Dave J
Both my '70 L46 cars are bone stock originals, and run fine on 91 octane premium fuel.
Old Feb 16, 2013 | 11:26 PM
Mike Ward's Avatar
Mike Ward
Today's premium has pretty much the same octane level as premium in 1969, despite the myths and misunderstandings that won't go away.
No octane boosters required- most are snake oil anyway.
Old Feb 17, 2013 | 12:07 AM
Brcmpbl's Avatar
Brcmpbl
I have a 70 L46, runs fine on premium pump fuel.
Old Feb 17, 2013 | 06:32 AM
Paul Workman's Avatar
Paul Workman
+ One more to the list: Wife's 69 L46 runs great on 93. No problems. But like da man said, temp & timing are important. I rebuilt the motor after the cam went flat on one lobe. I installed a 160º stat, stock vacuum advance dist...and that's about it. Oh! It is jetted a bit fat, and that helps too, I'm sure.
I learned that stuff from a time I had a 427 w/ 11:1 comp and a mechanical advance distributor. It was a pig; couldn't seem to keep it from knocking. I used gallons of octane (aka snake-oil) boost, to no good effect. Chucking that mech. distributor cured about 80% of it and the cooler stat just about cured it. I had to go with one range cooler plugs, and up a number on the (Holly) carb's primary jetting, with ever so subtle a tweak toward fatter idle on the air adjustment. I don't remember what the total advance was, but of course WOT (or anything near it) and the loss of vacuum pulled some timing too - at least until the "Rs" got "up there".
P.
Old Feb 17, 2013 | 08:57 AM
RMVette's Avatar
RMVette
My '70 L46 runs good on 93....but.....I do fill it up occasionally with 110 octane leaded racing fuel (cha-ching $). It does like that!
Old Feb 17, 2013 | 09:02 AM
bigvette1's Avatar
bigvette1
Engine condition, temps, timing and rich/lean setup determine what you need. If you knock with 93 probably too lean or too advanced. Set all up to stock and try a 1/2 tank of mid grade (couiple of cents off) and see how it runs. If it knock, fill the tank with 93 and drive it.
Old Feb 17, 2013 | 09:48 AM
1974ta's Avatar
1974ta
Default L46
My 70 L46 runs okay with the 93 Octane.
However, It idles waaay better and runs away better with a mixture of 110 octane and premium with timing set to factory specs. Usually I put in a 30/70 mix. I will occasionally get run on with 93 octane too. Meaning it will want to run after I turn the key to off position.
It is bone stock with all its original stuff down to the coil, distributor, and carb.
I cannot overstate how much better it runs with a little more octane. I can tell you it runs like it is brand new.
Bill
Old Feb 17, 2013 | 10:08 AM
longbros's Avatar
longbros
Looks like I am the odd man out here. My 70 L46 pings on high test fuel. I rebuilt it last Winter and it is stock. I have limited the vacuum advance, and the mechanical advance has the limiter on it as well. The carburetor is stock with stock jets, etc. I am running a 180 degree thermostat. It pings on light to medium throttle. One bottle of cheap octane booster and the ping goes away.
Old Feb 17, 2013 | 10:16 AM
Mike Ward's Avatar
Mike Ward
Bill
Octane rating of a fuel cannot have any effect on how an engine idles. Old myth.
Old Feb 17, 2013 | 10:40 AM
1974ta's Avatar
1974ta
Default Idle
Hi Mike,
I hear what you are saying, but when set to factory specs it idles a whole lot better with higher octane gas. This is real life experience and it is obvious not just a subtle difference. If I am running a bit low and have to fill with 93 octane pump gas you can actually tell when the good stuff has run out.
Granted the motor has some miles on it, but that is my story and I am sticking to it
Hi Longbros. Hope you are well.
What is interesting is if all I run is 93 high test in my L46 it will do the same as yours after 1/4 way through the second tank of 93 octane.
When I go up in town and fill with the 110 octane she runs so much better. I was frankly shocked at how much better.
Bill
Old Feb 17, 2013 | 12:52 PM
REELAV8R's Avatar
REELAV8R
Mike is right, octane rating will have no affect on idle or running other than to allow higher cylinder pressures without ping. It is more likely that the 110 your using is oxygenated fuel which will cause it to run better.
Old Feb 17, 2013 | 01:58 PM
1974ta's Avatar
1974ta
Default Octane
This may make sense. I wonder if there is no ethanol in the 110 either.
I was shocked at just how much better it ran with the 110.
I was smiling ear to ear!
Bill
Old Feb 17, 2013 | 02:00 PM
Mike Ward's Avatar
Mike Ward
Bill
Unless the car is suffering from percolation or vapour lock issues (almost unheard of on C3s with the correct fuel pump) ethanol content will have no effect either.
Old Feb 17, 2013 | 07:19 PM
REELAV8R's Avatar
REELAV8R
I'd have to disagree on that one. Ethanol burning engines need to be jetted richer than pure gas engines. The difference may not be noticeable if restricted to 10% or so and the carb is already tuned a little rich but if your tuned right on the line of lean and then add Ethanol you may find you suddenly have a problem with ping. An engine running lean will have a rougher idle than one jetted properly. Adding ethanol could then also affect your idle.
My fuel injected dd's automatically keep the mixture ideal for the fuel. That would explain why when you go from non-ethanol gas to 10% ethanol gas you'll get a noticable reduction in fuel economy in a modern fuel injected engine.
To L46 and lower octane
Old Feb 17, 2013 | 07:55 PM
Mike Ward's Avatar
Mike Ward
And what's the chances of all that being the case?
Old Feb 17, 2013 | 08:05 PM
REELAV8R's Avatar
REELAV8R
Don't know. Just saying.
Old Feb 18, 2013 | 09:25 AM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
I had detonation issues after my carb was just rebuilt by Lars and set my timing to 34° all in when I was running 10% 93 octane. I had about a 1/4 of a tank of gas. I went to my local ethanol-free station and filled up with 93 octane and went through about 1/2 a tank that afternoon - by the end of the day no ping.
Now, I will let others debate that the ethanol was the cause of my detonation problems, but until I hear otherwise, I felt that the ethanol was the issue.
