Reconditioning my standard column and have a couple questions.
1 - Shaft threads are beat up a bit but savable. I need to know the thread size and count so I can get the correct chaser and straiten them out (this where the nut secures the steering wheel).
2 - I have about a 1/16 sideways and up and down play (not in and out) in the top bearing. Should this bearing be replaced or is there play in this area?
I do have and read Jim Shea's papers as well as the AIM. Neither gives me the shaft nut and thread size or the play tolerance.
Thanks for the input.
Reason: Changed play dimension
Any other input?
