Holly Fuel pump ID
Old Feb 19, 2013 | 03:00 PM
illenema's Avatar
illenema
Default Holly Fuel pump ID
I need help Id'ing a holly mechanical fuel pump from a 74 454.
I dont have a camera to use today but here is a decription
Silver chrome type. 10 screws around the bottom extend all the way to the top portion, you can see the screws lengths looks like there are a 2 diaphragms top and bottom the 10 screws go thru both.
Looks like a large sandwich cookie.
All the replacement holly pumps dont have the extending 10 screws
leaking from the diaphragms i take it from the alcohol additives in the modern fuel.
I cant seem to find a model number-ware would that be please.
Old Feb 19, 2013 | 03:20 PM
illenema's Avatar
illenema
Default Here it is
I found a picture of it or one close, there are a old model i take ithttp://i261.photobucket.com/albums/i...psbf422adf.jpg
Old Feb 19, 2013 | 04:02 PM
BOSTONCAMARO's Avatar
BOSTONCAMARO
usually inlet size will help you narrow down gph etc..when comparing to new ones in catalog....any numbers at all on it? perhaps inside the bottom plate..
Old Feb 19, 2013 | 05:06 PM
MelWff's Avatar
MelWff
Look at GM part number 12355614, looks identical to the Holley pump
Old Feb 19, 2013 | 10:17 PM
illenema's Avatar
illenema
Its a 1/2" inlet (actually .686) so that puts it at a 130 GPH unit.
was just going to replace the diagrams, Local so. cal speed shop says no longer availe.
Thanks for replys
To Holly Fuel pump ID
