68 early vert cowl braces
Old Feb 21, 2013 | 10:55 AM
dntoearthman's Avatar
dntoearthman
Default 68 early vert cowl braces
Is it possible to install cowl braces, mine does not have them, I believe I have a set lined up w/ sadle bracket or is it going to be a pita? Taking out the dash panels is not an issue.
THX Mike
Old Feb 21, 2013 | 03:08 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
You could probably install them. The AIM shows them and the parts you will need.
Good luck.
Old Feb 21, 2013 | 10:33 PM
69vette19467's Avatar
69vette19467
My concern would be the connecting points. If the saddle bracket that you're referring to is the cast iron chunk, you'll have the attaching points for one end of each of the three braces on the driver's side. I'm guessing that the chassis brackets for the other ends would have to be obtained and welded into place. Same for both ends of the passenger-side brace. See the following for a partial pic.
http://forums.corvetteforum.com/c3-t...e-harness.html
Old Feb 22, 2013 | 01:37 PM
dntoearthman
Thank you sir, that was my fear, sounds like I would have to fab and attach some brackets.
Mike
Old Feb 22, 2013 | 04:09 PM
Paul L's Avatar
Paul L
I am not familiar with the 1968 but here is the saddle on my 1974.
Old Feb 22, 2013 | 06:38 PM
dntoearthman
Great pic, better than the AIMS manual, do you have AC? I think there may be a different brace for AC cars? I would really like to get them installed on my car, we have great roads in Nashville, but the ocasional pot holes kill me, I feel like I'm in my wooden go cart when I was a kid.
THX U Sir
Old Feb 22, 2013 | 07:01 PM
Paul L's Avatar
Paul L
This may help although it is 1974. Code C60 is A/C.
Yes, I have A/C. The upper brace is curved a bit to clear the A/C ductwork. I doubt that the saddle is different.
I do not have pics of the driver's side. Sorry! This was part of a heater core replacement.
Old Feb 22, 2013 | 09:48 PM
HUSKEE73's Avatar
HUSKEE73
Hello Mike, fellow nashville guy here, looks like that trans tunnel/saddle mount is riveted,got to put some thought into that one.if you need to look at the dash and tunnel area my dash is presently out,working on it.i do not have ac,but at least you can get an idea of how you want to tackle it. pm me for contact.
To 68 early vert cowl braces
