Side Pipe Cover Question
I have the rubber bushings that go to hang the actual pipes to take the vibration away, but I dont have the brackets that I see being sold as part of the mounting kit. I know I can buy them for just under $20 bucks apiece. are they really needed and does anyone have any pics of how they mount and what they support.
Also I've read somewhere that a carriage bolt is used to mount the pipes and the head goes into a slot on the underside of the frame. Is this correct?
Lastly does the cover mount using the same bolts that go thru the rocker panels once they are removed or do I need to find a different bolt?
Thanks for any help you can give me. Below is a pic of the pipes I have.
http://i1014.photobucket.com/albums/...ps9277758b.jpg
Rodney
I have fibreglass covers, nothing between the pipes and covers and the do NOT get hot. The pipes do use a carriage bolt and slot on the underside of the frame. You hav the bolts and rubber mounts on your pipes, i see them in the picture. My covers screwed to the same holes as the stainless rocker trim screwed to. My screw holes were rusted so I bought the rocker cover screw hole repair kit., basically a bolt/nut with a threaded hole in it.
http://www.parts123.com/parts123/yb....Z5Z5Z50000050G
Do you need this bracket if you use the fiberglass covers?
