Rusty Bolt extraction, Fast help please.
Old Feb 24, 2013 | 01:28 PM
Kevin68's Avatar
Kevin68
Default Rusty Bolt extraction, Fast help please.
Front bumper bolt twisted off, 7/16". Rusted in good and have been soaking in PB blaster. Despite squaring the twisted metal to a flat surface, I still managed to miss dead center with the drill but I think that part will be OK.
Questions: Is this extractor going to to the job? I've seen newer ones with a finer thread.
If I use heat on it am I going to damage the chrome?
Odds of sucess without bending the bumper in the vice?
Old Feb 24, 2013 | 01:46 PM
toolman0114's Avatar
toolman0114
Heat up around the bolt, keep the heat away from the chrome, use a small tip
Old Feb 24, 2013 | 02:00 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Forget that extractor. If it breaks on you, your screwed. Use a smaller bit and work your pilot hole closer to center. Then us progressive larger bits till you get to the hole size for the 7/16-14 tap. Get a tap and re thread the nut inside the bracket.
Old Feb 24, 2013 | 02:05 PM
Sidepiper's Avatar
Sidepiper
Old Feb 24, 2013 | 02:15 PM
Paul L's Avatar
Paul L
I get migraines from easy-outs. You have no real leverage and that bit can snap.
Sidepiper has a good suggestion. Or you might be able to grab it with a bolt extractor (these from Sears).
Old Feb 24, 2013 | 02:40 PM
stpman's Avatar
stpman
I have the same set as Paul, they work well. Another option if you have a MIG welder is to take a nut the will slip over the bolt and weld the center, the heat will help break it free
Old Feb 24, 2013 | 02:59 PM
Kevin68's Avatar
Kevin68
That is my fear. I tried reaming a twisted bolt on my front sway bar bracket with poor results. Of course I was working upside down on my back....Fortunately, at that location I could just use a nut to fix it. Here the nut is concealed. If I bungle it, I'm really screwed. I've got a teeny carbide dremel tip that could get the hole recentered.
Now that looks like the place to start. I've got a full 9/16" of bolt sticking out. Any chance I split the bolt extractor? I'll probably bend the bumper before that happens, though.
Thanks for the ideas, always willing to hear more. I got other commitments the afternoon, so I won't back on this for a while.
Any other thoughts on heat damaging the chrome?
Old Feb 24, 2013 | 03:04 PM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Gunk makes a product called Breakaway. Spray it around the area. Let it soak in and see if it works. I use it with great results at work.
Old Feb 24, 2013 | 03:12 PM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Kroil works better than PB Blaster in my experience also...
Old Feb 24, 2013 | 03:20 PM
georgiaboy's Avatar
georgiaboy
Must be something I am not seeing. Can you get hold of it with vice grips and gently work it back and forth until it will turn????
Old Feb 24, 2013 | 04:00 PM
Kevin68's Avatar
Kevin68
Already partially rounded off the threads with vice grips. Note the shine on the threads toward the camera. Assuming I could get vise grips to grip that tight, I'd need vice grips with a cheater pipe to get enough torque.
Old Feb 24, 2013 | 04:16 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Heat the part, then hit around the threads with a candle. The wax will melt and wick down into the threads, then latch on to the stud with vice grips.
Old Feb 24, 2013 | 04:18 PM
toolman0114
Heat it up using a small brazing tip and keep the heat to the base of the bolt, chances are the chrome will be ok as long as you don't over do the heat. If the chrome does turn blue it can be polished out, like you do with chrome headers. Heat and vies grips should work, done it lots of times
Old Feb 24, 2013 | 04:19 PM
Paul L's Avatar
Paul L
Those extractors are hardened steel. They will not bend/break. And you have the leverage of a ratchet handle with socket or even a breaker bar with socket on them. I would do the wax trick before you start.
Old Feb 24, 2013 | 04:24 PM
my 76 ray's Avatar
my 76 ray
Those things NEVER work on a rusted bolt. Think about it. You break a bolt so you drill a hole in it and try to twist it out with something that is half the diameter of the original bolt you broke.
If you somehow manage to snap a brand new bolt then they will work.
At least that's been my experiece.
Old Feb 24, 2013 | 04:29 PM
georgiaboy's Avatar
georgiaboy
I have broken easy outs before. Then the hole is plugged up and you won't be able to drill it out. I believe it will break long before you break the bolt loose. Wire brush the vice grip jaws to make sure they are clean (fairly new is good)
Old Feb 24, 2013 | 04:43 PM
John 65's Avatar
John 65
How about grinding it down flat to the surface, then use several drill bits to drill it out to the correct diameter so the weld nut can be retapped. (If all else fails)
To Rusty Bolt extraction, Fast help please.
Old Feb 24, 2013 | 04:45 PM
Ironcross's Avatar
Ironcross
Heat!...wrap a water soaked towel around it.....I have never seen a chemical work on severe rusty bolt problems
Old Feb 24, 2013 | 07:04 PM
SIXFOOTER's Avatar
SIXFOOTER
+1, this will work
Old Feb 24, 2013 | 07:18 PM
72LS1Vette's Avatar
72LS1Vette
I have always heard that Kroil is the best penetrant but I have never seen it in any of the common auto parts stores. I have used PB Blaster successfully many times but you have to be a little patient. Spray the bolt before you leave for work, spray it again when you get home. Repeat for a few days. Clamp your Vice Grips on the bolt and try to get it to move a tiny bit. Once the bolt moves even a hair you know you are going to win. Keep wiggling the bolt back and forth without applying too much pressure and keep spraying the PB Blaster. The bolt will gradually move more and more until you can thread it out.
I have drilled out bolts successfully also but I only do that when I can't get a vice grip on the broken piece. It's very difficult to get a drill bit in the center of an uneven surface and if the bolt is a grade 8 it takes a long time to drill it out.
Rick B.
