68' wiper motor question
Found it. check this out.
http://forums.corvetteforum.com/c3-g...d-69-72-a.html
shmoky
You can find a ton of info on our site about the 68 motors too.. Here is the main link to all that info.
http://willcoxcorvette.com/advanced_...&x=-987&y=-172
i will look for Cardone unit locally, if i can't find it hopefully Willcox has one.
Ironcross...what does "A-1" mean??? Rick
I have a video on how to bench test your motor on our web site... just enter the year, select tech video's from the middle box and search wiper... you'll find it. I'd hate to see you buy one and have the same issue. .. .
Willcox
Willcox
btw, i just received a new turn signal switch, and was testing it out via your tech procedure....Continuity was perfect on everything, EXCEPT last step when you check flashers.....i got continuity on post 1,2,3,5,6, but not 7???? are you sure i should get continuity on 7 in flasher pushed in position? thanks a bunch, Rick
Ok.. looked at my three year old paper.. lol.. yes.. it is correct. With the turn signal switch in neutral...
Keen, they are a great vendor, ungodly good people and plenty of knowledge... We just had the luxury of knowing there was an issue with the imported switch... else it would be us trying to solve the problem.
