Replacing speakers
Old Mar 1, 2013 | 11:58 PM
redwhitekat's Avatar
redwhitekat
Default Replacing speakers
I plan on replacing my speakers on the 74 when it gets a bit warmer. Are these hard to do ? I know I have to drop the steering colum anything else I should be aware ??
Old Mar 2, 2013 | 12:28 AM
F22's Avatar
F22
On my 74, the dash was already out and installed 4x6 plate speakers underneath. The only problem was the two 'grill' areas that have all those little holes, totally turned to chunky dust! So I gutted the holes and installed plastic and metal speaker grills, on top, with the dash in between and the speakers undereath.
The curvature of the dash makes for some problems too, but they were overcome and it looks sanitary. Also soldered ten feet of wire to each terminal, so it's ready to route and hookup later on.
Old Mar 2, 2013 | 05:58 AM
toolman0114's Avatar
toolman0114
It's a huge job, especially if it is just to change the speakers. If you are changing the dash then it is worth it. the other option is putting speakers in the kick panels, and buying new kick panels with the speaker hoes in them.
Old Mar 2, 2013 | 11:20 AM
redwhitekat
Oh really is it that bad now u guys are scaring me
What about just doing the passenger side speaker that's the one that has a crackle to it would just doing one be easier
Old Mar 2, 2013 | 11:30 AM
BeansWorld's Avatar
BeansWorld
The job is not difficult, however I would recommend you place the removed screws in a bag and label them so make re-assembly easier. And sometimes screw holes just don't seem to line up when you're ready to put back together. Standard C3 stuff.
The passenger side is much easier to complete, the lower dash pad can be removed entirely. I lowered the driver side lower dash pad without removal, and barely had enough room to work without total removal (remember gauge cluster etc it attached). I did unbolt the steering column and let it hang to get a few extra inches.
Many talked about removing the upper dash pad to remove/replace the speakers, but this is not necessary. This was my major concern, as its difficult to remove the upper dash pad without causing damage (many are 40+ years old and are fragile).
Have fun!
Old Mar 2, 2013 | 11:45 AM
MrJlr's Avatar
MrJlr
Just do the passenger side....trust me.
Old Mar 4, 2013 | 08:24 AM
Commodore's Avatar
Commodore
I've been 'Corvette-less' for 17 years and just got another one (that makes this Corvette number eleven). The last was a new LT-4 convertible which explains my dismal post count.
The stock stereo and the dash speakers in the '75 I just got work but the entire package sounds awful (speakers and radio are preparing to die I think). I am not in a hurry to jump through all the hoops needed to change the speakers in the dash but will likely go the kick panel route. A 38 year old Corvette is not an ideal listing environment anyway so quality kick panel speakers should be just fine in this car. I also intend to change the head unit which leads me to this question. Almost all the "it looks stock" aftermarket replacement radios are for a four speaker installation. Short of using the fader to not send signal to two non exsistant speakers can these aftermarket radios be ordered to sum their output to just two speakers? I'm not a fan of hacking up an interior to add speakers that weren't available when the car was manufactured. The entire radio redo can be returned to stock very easily should I sell the car so the factory Delco and its amp will go in an airtight plastic bag and adorn a shelf in the garage until that day arrives.
Nice to be back.
RB
Old Mar 4, 2013 | 08:47 AM
erikm12's Avatar
erikm12
I sent my orig radio out to get cleand and refreshed. I also went with stock speakers back in the dash. Drop the column like you said and you can do it. Had to do a little prying, and your arm will get scraped up a little but be patient and you can get it done. Took me maybe a half hour total to get the drivers side one in. I will say out of the 4 studs I did break one off because I just couldn't get it to work with all 4. Is that a Bubba thing?
This was a 72, couldn't imaging there would be much difference if any
on a 74.
Old Mar 4, 2013 | 09:28 AM
Stroh's Avatar
Stroh
Hey Redwhitekat,
Good advise above, to be certain. Labeled bags with screws is a must or the reconstrcution stage will have you pulling out hairs and taking forever. MrJr's advice about the passenger side is actually very good. That side is EASY. I think it's four screws that hold that passenger side dash pad, a little jockeying to get the heat/air duct work out of the way, then another four screws to remove the bottom of the speaker support, and there it is.
BUT. Here's the problem with the driver side: Yes, you need to drop the steering column which is only a slight pain in the keester, getting under the dash down by the pedals, probably upside down in you seat, feet up through the t-tops opening. But then you need patience and luck and HEAT. The driver's side dash pad will not be easily removed above the steering column, so that arched opening in the pad that sits on the steering column (which is thin and fairly fragile) will have to be delicately pulled out, after disconnecting the wiring to the back of the speedo and tach (this is a royal PITA because you have very little room to blindly work). Once that panel is removed, the speaker is as easily accessible as it is on the passenger side. If you are removing the dash to work as well that makes it easier, but again you will want a WARM environment, because as with the drivers side dash panel, it will be even more brittle in the cold, it won't flex and for the attempt to find better sound you will be rewarded with a cracked drivers side pad and / or dash.
I replaced the speakers and re-dyed the entire interior, so it made sense when I had eveything out to do both speakers, but I -- in hindsight-- if I had to do it again, I wouldn't even think of the drivers side. I'd just build a speaker box for the back and correct the problem with richer sound that way. And drop some speakers below in the kick plates as someone suggested above.
Good luck. And if you go that route of under the dash, take your time and be gentle with those REALLY old pieces... They're crazy expensive to replace.
Old Mar 4, 2013 | 09:33 AM
redwhitekat
Thanks all ill probably stick to the passenger side speaker as that's the one making a ****** noise ill leave the drivers side for another time as I do wanna enjoy driving it more than wrenching it lol
Old Mar 4, 2013 | 02:23 PM
Paul L's Avatar
Paul L
I wouldn't start pulling the driver's side dash apart. You can do more damage than good. The upper dash pad will come out if you work carefully and with a bit of heat (e.g. low setting on a hair dryer) as Stroh suggests. Then you have lots of room to work. Replacing one speaker (passenger side) without a technical match on the other side does not make sense.
This was my choice for the kick panels and some bass in the back.
Old Mar 4, 2013 | 03:43 PM
Commodore's Avatar
Commodore
I would love to have a step by step direction sheet on that pad removal - we all would. Finished product looks great. Nice job!
RB
Old Mar 4, 2013 | 05:13 PM
Paul L's Avatar
Paul L
RB
I don't have a step-by-step on that job. It was part of a heater core job. I took the opportunity to put in a KHE-300 and Pioneer speakers up top and Polks down below. And the Blaupunkt in back. That was three years ago. I don't recall the upper dash pad being a problem when eased out and up carefully. Willcox has a good read on this. *Edit* -Can't find it now?
The Blaupunkt sub-woofer has a self-powered amp connected directly to the battery.
Old Mar 4, 2013 | 05:32 PM
Mashman's Avatar
Mashman
There is no reason I can think to remove the drivers side dash, pull the passenger side dash, and then remove the top dash.
This is how I do it.
1) Remove header moldings, sun visors, and a pilliar moldings.
2) Remove passenger side dash pad.
3) Remove top pad support screw from bottom of top dash pab.
4) Remove wiper switch.
5) Remove screw holding driver side dash - 2 on each side, and 3 on top.
6) Disconnect passenger side speaker.
7) Pull the top dash pad gently towards you, away from the windshield. While doing this, lift the edge (the one facing you) of the dash pad a little. This is done to disengage the clips on the front of the pad from the birdcage. Be carefull the pad can catch on the defroster vent - I pull down on the vent when I do this part, and when I'm putting the pad back in.
8) Now the part to be very carefull. It's easiest to have some help here. The pad can not be removed without bending it slightly. With a helper holding the passenger side of the pad down, gently lift up the center of the pad, while gently pressing down on the passenger side. Do this very gently, and only enough to clear the passenger side a-pilliar.
9) Disconnect the drivers side speaker, and remove the dash.
I also remove the steering wheel, removing it provides a lot more room to work in. Also, In the list I had the screws on the sides of the drivers dash being removed. This is to allow the drivers dash to move slightly. If you need it to move more than a sliver, loosen the two bolts holding the column to the firewall, and the two bolts holding the column to the supports. This will allow you to wiggle the dash a little more. Try not to move the dirvers dash to much, the bottom can break on the steering column.
To Replacing speakers
