body c3
Old Mar 3, 2013 | 06:48 PM
mason pro's Avatar
mason pro
Default body c3
How do I take body off
Old Mar 3, 2013 | 07:00 PM
briankeery's Avatar
briankeery
Well, first welcome, secondly.......try posting your request in the tech/performance section of the forum. I'm sure you will get a detailed answer there, good luck.
Old Mar 3, 2013 | 07:58 PM
gdh's Avatar
gdh
What year and do you have your year's Assembly Manual? Posting as Brian suggested is good advice.
Old Mar 3, 2013 | 08:43 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
taking the body will lead to......the very expense, while I am at it ~ Disease.
There is no cure.
Old Mar 3, 2013 | 09:42 PM
spdrcr29's Avatar
spdrcr29
There is no cure.
Isn't that the truth!
Old Mar 4, 2013 | 03:19 AM
tfi racing's Avatar
tfi racing
Simple.Disconnect battery.Remove body.There-you're done.
Old Mar 4, 2013 | 11:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Do you need to? My advice is not to do it if you do not have to. There is a very common misconception that all C3 bodies must always be removed from the frame in order to be restored. Not true. You can complete a reasonably thorough restoration with the body on the frame. The assembly instruction manual (AIM) helps since it shows the body mounts. Do the Google thing. There are three or four Corvette restoration books which discuss removing the body.
Old Mar 4, 2013 | 12:40 PM
gcusmano74's Avatar
gcusmano74
There is no cure.
Don't we know it!
But seriously, it's a bunch of work. It will eat up more time and money than you budgeted. I had to do mine a few years back, just to replace three rusted away body mounts. By the time I had it back together, six weeks later, the engine was rebuilt ($$$$) and the unplanned "incidentals" were another $1500 on top of that.
Old Mar 5, 2013 | 09:12 PM
mason pro's Avatar
mason pro
Its all done just parting out thanks to all of u
To body c3
