My '77 has loose driver's side mirror. Have looked at past posts and learned mirror should pull off from plastic tabs exposing loose bolts that can then be tightened without removing from door. Glass part is loose but will not pull loose from housing. I have used small pry bar behind glass and this didn't help. Mirror is manual and has no inside control.
Could someone please help before I break something.
When I pulled my mirror off when I painted it, I took the two bolts off inside the door panel and removed the mirror. Looking up into the mirror there was another bolt that was used for tightening the top part of the mirror.
OK, the door panel has to come off, what about the window glass, is it going to be in the way? Even with mirror removed from door how can I get the glass of mirrow back into position...it is also loose in there with something probably broken? Thanks for any help.
You don't have to take the window out I don't think. It would make it easier. Just use a bunch of extensions and I think the nut is a 3/8s. Once you get the mirror off, you will be able to see the nut the holds the top part of the mirror on. I have never taken mine apart so I can't help you with that.
Have someone hold the mirror while you take the nuts off, I would hate for you to drop it. You do have to have the window all the way up to get to the nuts that hold it to the door. There is a plastic/rubber seal between the mirror and door, don't loose it and while you have it off, clean it up so you never have to do it again.
Make sure there are no kids around while you are doing this, it can be very frustrating and you will swear. If you can, break your wrist, you will be able to get your hands up in there a lot easier and it will make the job go so much quicker
Purchase the 77 assembly instruction manual (AIM). It shows how the mirrors were installed. Helps knowing how they were installed before taking one off.
AIM also shows where the lower window stops are located in the event you have to lower the door glass at tad to reach the mirror nuts.
Wasted day and still have loose sport mirror. With door panel off unable to get anything on the one nut behind door glass I could see to loosen it...the other one is in never never land and never did see it. Looks to me that window needs to come out and not getting into that just yet...Hey Buba, got any duck tape to spare? ...and I did crack the mirror.
