steering wheel question
Old Mar 6, 2013 | 05:19 PM
straitjacket's Avatar
straitjacket
Default steering wheel question
i just pickep up a 77 and i have the "vega" style steering wheel. is this original? i thought the vega wheel was a 76 only steering wheel. am i wrong? also can someone tell me what i need to look for to find out if i have an l 82?
billy
Old Mar 6, 2013 | 05:50 PM
John 65's Avatar
John 65
Only the tilt-tele columns got the 3 spoke wheel for 77.
Old Mar 6, 2013 | 05:58 PM
John 65's Avatar
John 65
Ooops forgot about the 2nd part of your question. The engine codes for L82 in 77 was CDL if ya have a stick, CLF for an auto.
Old Mar 6, 2013 | 06:27 PM
Brcmpbl's Avatar
Brcmpbl
Old Mar 6, 2013 | 07:13 PM
my 76 ray's Avatar
my 76 ray
In other words, the non tilt/tele steering columns had the Vega wheel in '77.
Old Mar 6, 2013 | 07:15 PM
Paul L's Avatar
Paul L
Yes.
Old Mar 6, 2013 | 07:39 PM
straitjacket
thanks guys. so it was an option and wouldnt be totally incorrect to put a tilt /tele steering column in it. i was a pretty large guy (280) and really liked it in the 81. but i have been losing some weight so it may not be a necessity like it was. i have yet to even get in the 77. the plan is to keep the 77 as original as possible. i may change a couple of small things but nothing that couldnt be fixed back correctly. my 81 was just so gone from original i pretty much i pretty much just kept going that way. im missing the ac compressor under the hood but it looks to be pretty much unmolested. i dont think it was originally a black car but it does carry the color well( very straight ,no waves.) this 77 i do believe will be a good daily driver unlike the 81. i loved the attention th 81 garnered and i will miss her but i see myself axctually driving this car on much more of a regular basis just because its a bit tamer.
thanks for the info guys
billy
Old Mar 6, 2013 | 08:16 PM
gbvette62's Avatar
gbvette62
As said above, the standard column, came with the "Vega" steering wheel, while the optional tilt/tele column, came with the 3 spoke, leather wrapped wheel. This was also true for 78 and 79.
You can swap a T&T column, into your 77, but you need to make sure that you get another 77 column. 77's are a one year only column, because the wiper switch is part of the turn signal stalk. All other year Corvettes, have the wiper switch, on the dash.
To identify which engine, your 77 originally came with, check the VIN number. The 5th digit will be an "L", if it came with the base L-48, or an "X", if it came with an L-82.
Once you've determined from the VIN, which engine the car came with, you can verify if you still have the original engine from the code stamped on the engine pad. If it is a 77 L-82, the suffix codes will either be a "CLD" (not CDL as posted by John 65) or "CLF". A 77 L-48 will have a suffix code of "CHD", CKD", "CKZ", "CLA", "CLB" OR "CLC"; depending on the trans, and emission system used.
Old Mar 7, 2013 | 08:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
78s without T/T may also have gotten the Vega wheel.
To steering wheel question
