Steeroids rack ...
Terry
http://forums.corvetteforum.com/c3-g...-purchase.html
Another CF member (Roadworn) had to struggle his way through another vendors offering and I then gave him a comparison to my install (begining with post #43):
http://forums.corvetteforum.com/c3-t...1971-c3-3.html
No intention here other than comparison information between Roadworns situation and my own experience. Take it for what it's worth and good luck.
One almost cut of one entire revolution on the steeringwheel "lock to lock" and get a more modern and distinct feeling when driving.
The Steeroids did clear my hedders but only just..
I run a 454 with the large 2-1/8 Hooker Supercomp hedders but other hedders may be of a different design and may cause other problems..?
One thing to bear in mind and pay attention to is that you must make shure that all the welding spots (correct word?) are removed both on the frame and on the brackets where in contact with each other.
Otherwise the parts may "ride" on these spots and eventually get loose.
Re-check and aftertighten the installation a couple of times after installing to make shure everything sits where it should.
Heres a couple of pictures from the tightest spot.
//Ricky.
//Ricky.
Thanks,
Dave.
