Front Air Dam Support
Old Mar 10, 2013 | 01:35 PM
holden7896's Avatar
holden7896
Default Front Air Dam Support
I'm about to put on the front air dam on my 82 but the hook that supports the middle of it is missing. Is this gonna be a problem with the fiberglass one I bought? If so has anyone figured out a way to support it without that hook? Pictures would help. Thanks
Old Mar 10, 2013 | 05:40 PM
alconk's Avatar
alconk
I'm not for sure what hook you're talking about?? My 82 has no hook. The air dam is bolted to the bottom radiator support and two bolts one on each side to the lower fender with push pins into the sides.
Old Mar 10, 2013 | 08:21 PM
holden7896's Avatar
holden7896
The hook on the bumper support
Old Mar 10, 2013 | 08:31 PM
alconk's Avatar
alconk
Oh ok, the one in the center. I never knew what that was for?? Shouldn't have any affect on your air dam.
Old Mar 10, 2013 | 10:39 PM
holden7896's Avatar
holden7896
Ok good. I just didn't want it to sag because of driving
Old Mar 10, 2013 | 10:41 PM
t dino's Avatar
t dino
i have 1980 corvette i had shop replace the air dam and valances as i could not get alighned and sealed properly my self i have no hook on mine
Old Mar 11, 2013 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by t dino
...i have no hook on mine...
You should. My 80 has one.
Old Mar 11, 2013 | 12:55 PM
alconk's Avatar
alconk
Easy Mike, you have a vast amount of information.., I don't get what the hook has to do with the front air dam?? My air dam is not even close to it and has no affect on how it fits??
Old Mar 11, 2013 | 01:11 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by alconk
...I don't get what the hook has to do with the front air dam?...
Possibly nothing. The air dam/baffle fits around it. Here's the hook.
Not the best pic, but good enough for illustration purposes. The baffle on this car is not yet completely installed. Spoilers are also missing.
From the front:
If the new Photobucket does not improve soon, I will be making the jump to Flickr.
Old Mar 11, 2013 | 06:10 PM
alconk's Avatar
alconk
MIne don't look like that.
Old Mar 11, 2013 | 07:13 PM
RaptorTest's Avatar
RaptorTest
That hook is necessary to keep the air from pushing your air dam into the pavement at high speed (e.g. 40-50 mph). If you don't have it, and do not find alternate means to secure the front of the air dam, you'll be buying another one...ask me how I know!
Old Mar 11, 2013 | 07:56 PM
c3corvettes's Avatar
c3corvettes
I agree with RaptorTest. The purpose for the hook is to prevent the air dam from scraping the ground as the car is moving at high speeds. The air dam catches cold air and forces or redirects it into the engine bay. Take the car to a machine shop and have them fabricate a metal piece and have them weld it to the bumper support. I suggest a short piece of metal with a lower and an upper hook (kind of in the shape of a "C") this way the dam won't be forced down or up. This is the case with the original air dams made of flexible polyurethane. You might be able to get away without a hook if your buying an aftermarket fiberglass one as that one will be more rigid and less flexible. Good luck.
Old Mar 11, 2013 | 11:12 PM
Yellow1980's Avatar
Yellow1980
Here's what it looks like on my 80:
One thing I did notice with it is, if the spoiler is not resting on top of it, the engine can get a lot warmer at highway speeds. I check before any cruise I go on to make sure the spoiler has not lifted up.
Old Mar 12, 2013 | 12:00 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you have the fiberglass damn, I don't think missing the hook will hurt you... The urethane part was very flimsy and as stated above, if you didn't have it the air will pile drive it to the pavement.
Willcox
Old Mar 12, 2013 | 12:01 AM
holden7896's Avatar
holden7896
Ok good. I have the aftermarket fiberglass one.
Old Mar 17, 2013 | 12:31 PM
alconk's Avatar
alconk
Ok I'm trying to figure this out. My car is missing the whole thing except the metal bracket that is shaped like a "C". In all the pictures I've seen they have a wedge shape piece. Now does that cover the "C" shape metal piece and is the wedge plastic or something?
Old Mar 17, 2013 | 09:23 PM
Yellow1980's Avatar
Yellow1980
Here's another view that shows how it's connected to tow hook and how it holds up the spoiler:
To Front Air Dam Support
Old Mar 17, 2013 | 09:37 PM
Arkyvette's Avatar
Arkyvette
My 82 doesn't have this either. Maybe broken off as some of my air dam is cracked up. Once I get it back off jackstands this will be useful thread. Subscribed.
Old Mar 17, 2013 | 09:39 PM
qwank's Avatar
qwank
my "tounge" is missing, but I was able to bolt the air dam to the tow hook
Old Mar 17, 2013 | 10:04 PM
Yellow1980's Avatar
Yellow1980
This part does not appear in the 1980 assy manual , don't now if it made it in the later year manuals.
