Controlling dual fans seperately
Old Mar 12, 2013 | 10:03 AM
MrJlr's Avatar
MrJlr
Default Controlling dual fans seperately
I have a Dewitt's rad and dual electric fans.....
Both fans come on and off together...but I would like only one to come on and only if needed - the other come on with it...
What's the best (and easiest ????) way to go about this ?
Old Mar 12, 2013 | 12:57 PM
REELAV8R's Avatar
REELAV8R
Wire each fan to a separate thermo switch. Each switch at a different temp range. Top hole on the water pump probably available to put a thermo switch into.
Old Mar 12, 2013 | 03:52 PM
MrJlr's Avatar
MrJlr
Does anyone make an electronic controller ?
Old Mar 12, 2013 | 05:38 PM
REELAV8R's Avatar
REELAV8R
Yes there are electronic controllers available. I'm not sure what they are but a search for electric fans would give you some good ideas as lots of people have done many different kinds of installs with electric fans.
Old Mar 12, 2013 | 07:56 PM
U17's Avatar
U17
We seperated mine... So if one relay ect fails there will still be some cooling... BUT,they still get the signal from one source ..And one comes on now with the A/C selected... Which I've never done,tops are never on...
Old Mar 12, 2013 | 08:54 PM
redwingvette's Avatar
redwingvette
I put one on the thermal switch and the other on a toggle switch. 80% of the time I just run the one fan.
Old Mar 13, 2013 | 08:32 PM
donnie1956's Avatar
donnie1956
http://www.haywireinc.com/index.cfm/...prod/prd51.htm
Old Mar 14, 2013 | 02:22 PM
77C34SPD's Avatar
77C34SPD
If you are going to use another relay and sender, I would see if you could buy a 1/4 npt switch or you can do what I did and turn down a 3/8 npt sender and rethread, and install in the radiator drain petcock. You will need to ground the radiator to the chassis. I would trust that more then a compression fitting Name:  100_1225.jpg
Old Mar 14, 2013 | 05:16 PM
CraigH's Avatar
CraigH
This is exactly what I wanted with mine.
But I wanted to use just the factory sender unit.
Could not find what I wanted so got a friend to build one for me.
(However Dakota Digital do have a fairly good one as well - have not tried it but on paper does a fair amount)
- Press and hold Fan button 1 to set on point for fan 1 and Fan 2 on will be set 10 degree hotter.
- Press fan 1 or 2 to force on either fan. (Manual mode)
- Press and hold Fan 2 button then you can increase or decrease the gap between fan 1 and Fan 2 on points.
-Dual Press 1-2 or 2-1 allows you to then move fan off points up or down for either fan.
Covered on page 20,22 & 30 of my build thread
http://forums.corvetteforum.com/c3-g...1-journey.html
http://forums.corvetteforum.com/c3-g...ourney-20.html
http://forums.corvetteforum.com/c3-g...ourney-22.html
http://forums.corvetteforum.com/c3-g...ourney-30.html
Old Mar 14, 2013 | 05:41 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
All you have to do is put a cut off switch in one of the switch sensor (gray) wires. That way it's automatic with one or two. Since this a ground wire, you don't need a big amp rated device. A small toggle switch will do the job
Old Mar 14, 2013 | 06:56 PM
MrJlr's Avatar
MrJlr
Yes, but that would be manual...I want one fan to come on at like 185, and if it got to 190 the other fan.....automatically.....
P.S. it's a DeWitts....setup.....!
To Controlling dual fans seperately
