Hot 69
Old Mar 17, 2013 | 08:12 AM
Jim Myers's Avatar
Jim Myers
Default Hot 69
My 69 will continue to put out warm air through the vents when the AC control is on vent and cold Any suggestions?
Old Mar 17, 2013 | 09:37 AM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
Does it put out any cold air at all? Could be freon issue.
If freon charge is ok, there are vacuum actuators that close fresh air doors in your duct work. One of the actuators could be toast or you could have a broken door or hole in one of the doors. They are made of thin plastic.
Gary
Old Mar 17, 2013 | 10:12 AM
Jim Myers's Avatar
Jim Myers
Yes Gary the AC works OK, I will reserch the actuators. Do you know the location of the doors?
Thnaks
Jim
Old Mar 17, 2013 | 10:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Under the right side fender at the end of the wiper trough; kick panel vent passenger's side. If you have a small block, the water shut off vavle could be stuck open.
Hood weatherstripping in good shape?
Old Mar 18, 2013 | 06:48 AM
Jim Myers's Avatar
Jim Myers
Thanks, that really helps.
To Hot 69
