Help! Hurst shifter issues
Old Mar 20, 2013 | 05:18 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Originally Posted by msteno
So I tried this and it went the same. I said screw it and decided to rebuild the shifter. After taking it apart and seeing all that crap in there, there's no question the lube had all dried up and in it's place were rocks, preventing the reverse "peg" to move.
Now it works like a charm! Shifts are clean and easy, reverse still needs a nudge but not bad at all, and the neutral "gate" is clear as day.
Thanks for all your advice and guidance!
As usual, Corvette Forum saves the day!
That's the way it should be. It prevents "accidental" shifts into reverse.
Old Mar 20, 2013 | 08:15 PM
Big Block Dave's Avatar
Big Block Dave
I guess there was a sudden internal structural problem! Glad it all worked out.
Old Jul 15, 2013 | 01:20 PM
Mikesfreetime's Avatar
Mikesfreetime
What did you follow to rebuild it? Any manual? Or did you just take it apart and remember how it went back together?
