Correct LS5 alternator?
Old Mar 18, 2013 | 04:48 PM
tom00799's Avatar
tom00799
Default Correct LS5 alternator?
This is the alternator that came on my 70 LS5. It's supposedly a 100 amp alternator. The ground bolt hole is right up against the valve cover (Crane reproduction). Is this the correct alternator? The AIM shows the electrical connection coming in from the side like you would see on a "9 o'clock" alternator but shows the ground bolt in the same location as mine. The "9 o'clock" alternator has the bolt hole near the top so it would resolve the problem. Thoughts?
Old Mar 18, 2013 | 05:02 PM
MelWff's Avatar
MelWff
there is a picture in this link of the alternator and the plug is not on the top
http://forums.corvetteforum.com/c3s-...eed-coupe.html
Old Mar 18, 2013 | 05:50 PM
Ironcross's Avatar
Ironcross
I doubt that its 100A alt, not with that style ....A simple 10 minute fix is to re-clock the alternator to the position you need......
Old Mar 18, 2013 | 08:58 PM
Mooser's Avatar
Mooser
Check the unit, most 10si alt are 63A units although aftermarket ones are being rated with higher outputs
You'll need to reclock it around 90 deg. to get it to fit
Even then it's tight to the valve cover depending on your belts.
Mooser
Old Mar 18, 2013 | 09:08 PM
Mike Ward's Avatar
Mike Ward
Stock alternator would be 42 amps stamped P/N 1100900, 61 amps with A/C stamped P/N 1100884
Old Mar 18, 2013 | 10:39 PM
gbvette62's Avatar
gbvette62
No 70 Corvette (or any 68-82 Corvette) ever came with a 100 amp alternator.
The part number and amperage, should be stamped in the body, right near the bolt hole where the adjusting bracket attaches.
Old Mar 19, 2013 | 09:53 AM
tom00799's Avatar
tom00799
Thanks everyone. The alt on Mooser's car is what I need. My car is an A/C car and the part number on the unit is not 1100884 and is stamped 100A so it's off of something other than a corvette.
Old Mar 19, 2013 | 10:39 AM
Mooser's Avatar
Mooser
Re-Clocking a 10si is pretty straight forward, or if it's not something you want to get into, take it to a local alt/starter shop and they should be able to do it while you wait.
HIH
Mooser
Old Mar 19, 2013 | 11:34 PM
71corvette's Avatar
71corvette
I've got a 1971 LS5 and the alternator on yours is definitely clocked wrong. The regulator wires should be pointing towards the driver fender. The assembly manual shows it in this position.
To Correct LS5 alternator?
